Electrical Engineering question , do pedals not protect you from Widow makers?
Discussion in 'Glowing Bottle Tube Amp Forum' started by jomazq, Oct 9, 2019.
  1. jomazq
    jomazq Tele-Meister Silver Supporter
    whittier, ca
    maybe a dumb question: if you have a widow maker amp, would pedals protect your from electrocution ? like a buffer pedal before input ? would the 120v be connected through ground side , still ?
  2. Speedy454
    Speedy454 Tele-Holic
    Highland, IL
    Most likely they will not protect you or isolate you.
    If you get a 'hot' chassis, the voltage will be on the outer ground connector of the chassis, right down the outer ground of the cable, right through the metal chassis of the foot pedal, right through the next outer ground cable, right to your guitar bridge/strings, right to you.
    jvin248, nojazzhere and KT89 like this.
  3. mfguitar
    mfguitar Tele-Holic
    Buffalo
    I think you are more worried about tube voltage, 120 would just tingle a bit :) A wireless setup would be better.
    charlie chitlin likes this.
  4. gusfinley
    gusfinley Tele-Holic
    SLC, UT
    Please elaborate on "widow maker amp."
    If iy want to be completely sure use one of those "hum bucking" boxes with a signal transformer in it,
  5. Mexitele Blues
    Mexitele Blues Tele-Holic
    Westminster, CO
    You could use an ABY pedal with a ground lift/isolation transformer.
  6. ICTRock
    ICTRock Tele-Afflicted
    Tampa,FL
    all you are doing is temporarily transferring fault to the pedal(s) until those are destroyed and that's no guarantee you still won't get bit as bad as if they weren't there ... it is a poor and equally expensive alternative to doing the right thing.
  7. wabashslim
    wabashslim Tele-Holic
    Sonorous Desert
    Yeah, well, 120v can tingle you to death. You're gripping a guitar around the neck with your sweaty left hand and you grab the mic stand with your right - if one or the other is hot your hands can lock on and down goes Frazier. It happens.
  8. Wally
    they are called widow makers because they have no power transformer or isolation transformer. They run the AC voltage directly to the circuit. They are sometimes called ‘American Five’ circuits....you can add up the first number of the tube designations and it will come very close to equaling the wall voltage back in the day.
    The lower power Silvertone single 6V6 amp-in-a-case guitar rig that came with a short scale, single pickup Danelectro is a widow maker. The amp/case that came with the longer scale, two pickup Dano has 2 x 6V6’s and a power transformer.
  9. fakeocaster
    fakeocaster Tele-Afflicted Silver Supporter
    Enniscorthy, Ireland
    Make sure that the amp is earthed properly and you won't have a problem.
    peteb likes this.
  10. Wally
    Unless an amp has a power transformer or an isolation transformer, earthing does not prevent possibilities of severe shock.
    cnlbb, sarnodude, DrPepper and 7 others like this.
  11. drf64
    drf64 Poster Extraordinaire Silver Supporter
    Ada, MI
    Do you have a widow maker amp?
    Wally likes this.
  12. 24 track
    kamloops bc
    I have a pine electronics Pepco widow maker and believe me as nice as that amp sounds the current goes right to chassis , at least pine was kind enough to post the transformer mod on line , I would not trust any amp that was not isolated from the current because in the correct circumstances you are the conduit for the full force of that, notice ther is no transformer on the voltage input
    DrPepper and Wally like this.
  13. gusfinley
    SLC, UT
    At the very least wire up an isolation transformer. I had a "widow maker" table radio on my bench once and it did some WIERD things. I finally wired up an isolation transformer I had laying around after it blew up my AUX out on my mixer!
    jomazq and 24 track like this.
  14. LightningPhil
    LightningPhil TDPRI Member
    Nottingham, UK
    It’ll help a lot if earthed properly by providing an easier current path than you do
    rolandson likes this.
  15. rolandson
    rolandson Tele-Meister
    Cascadia
    Before the advent of wireless, I would get periodically zapped by the fine wiring that Mr. Gilbert's third grade cooking class students did on the electrical systems of some of our finer establishments...
    So I took my strings and bridge out of the circuit by simply cutting the ground lead to the bridge (actually the trem spring claw on Strats but what the hell), after which I did a thorough shielding job.
    No hum, no zap.
    Owenmoney and LightningPhil like this.
  16. Bill Moore
    Bill Moore Tele-Afflicted Silver Supporter
    Silver City, New Mexico
    I'm personally more concerned with the 120V zap than I am the high voltage, LOW AMPERAGE bite you get from most tube amps! There is 15 amps minimum available at the wall outlet!
    Wally and nojazzhere like this.
  17. getbent
    getbent Telefied Ad Free Member
    San Benito County, California
    the pedal won't save you.
    BobbyZ likes this.
  18. peteb
    peteb Friend of Leo's
    Cascadia
    This won’t.
    This will.
    Use a DMM and outlet checker, make sure the amp is grounded or plugged in properly, and then I do not think you can get shocked.
    matmosphere likes this.
  19. matmosphere
    matmosphere Tele-Meister
    earth
    https://robrobinette.com/Widowmakers.htm
    There is a detailed explanation of how to safely wire this up at the bottom of the page. If you don’t understand it or have no experience working on high voltage electronics then take it to a tech and have them do it. If the amp sounds good and is worth using then it is worth making it safe to use. Otherwise, pitch it and buy something else.
  20. tvas22
    tvas22 Tele-Meister
    My multi-pedal power supply is earthed through the amp - its plug just has a plastic earth pin (I’m in the UK).
    I have wondered how safe this is, as I have picked up quite a large voltage potential with my DMM between my pedals’ case and the amp’s ground when they were on but unplugged. But I assume it’s to cut down on ground loop noise?
