Efficiency of class A AB and B. What does it mean?
Discussion in 'Amp Tech Center' started by peteb, Jul 17, 2018.
  1. Old Tele man
    Old Tele man Friend of Leo's
    Once banned always banned
    Example of what viccortes285 describes above is:
    0W = 0A * any voltage
    9.8W = 0.025A * 400V
    As the bias is reduced, idle current increases, causing plate voltage (not B+) to be "sucked" down, ie: plate dissipation increases.
  2. elpico
    elpico Tele-Afflicted
    Vancouver BC
    Peteb,
    You’ve mixed up where to put that 70W number in your example. The 70W doesn’t tell you the power dissipated in the tubes, it’s the TOTAL power disipated in the speaker and tubes COMBINED. It’s the overall amount of power disipated in the system, and we’re trying to see how that power is divided between the parts in the system. That’s what efficiency means. If you had 1W in the load and the tube is also dissipating 1W then we’d say the system is 50% efficient because we have 2W TOTAL power disipation and 1W of that is making it to the speaker. 1W output / 2W total = 0.5 or 50% efficiency.
    In your example if we have 70W total in the system and 55W are being disipated in the load (speaker) then only 15W are being disipated in the amplifier (power tubes + transformer).
    70W total x 0.785 efficiency = 55W output
    70W total - 55W output = 15W wasted in the tubes
    15W disipated in 2 tubes = 7.5W per tube
    = well within their ratings and nothing “has to give”
    Modman68 likes this.
  3. peteb
    peteb Friend of Leo's
    Cascadia
    Elpico thanks,
    You are not saying that the tube is biased at 7.5 W are you?
    7.5/ 30 = 25% of MPD. The paper already gave the idle bias as over 70% of MPD.
    The two plates are dissipating the whole input power, 70 W. I will go along with you that the speaker is dissipating 55 W. The difference, 15 W would be energy used up in the process, this could be the wasted heat dissipation.
    These different interpretations results from different interpretations of dissipation.
    Plate dissipation, Ip*(Vp-Vc), is the input energy to the tube. It’s what gets calculated for the bias calculation. When measured at idle, it is the idle input energy, the idle plate dissipation. In class AB fixed bias, the plate dissipation increases with signal, in class AB cathode bias supposedly it decreases with signal, in class A, this plate dissipation is the same at idle and under full power.
    Then there is the other formula for dissipation.
    Power in - power out = dissipation
    Clearly these two dissipation’s cant be the same thing. To clarify, let’s call the second dissipation heat dissipation, or wasted energy, and the first one is DC energy input to the tube.
    To understand this, a ‘big picture’ understanding of dissipation is needed.
    Most people are not aware that plate dissipation gets viewed as both of these distinctly different things and that’s why there is so much confusion about plate dissipation and wasted heat energy.
  4. peteb
    Cascadia
    To make this point clearer.
    When they say the max plate dissipation for a 6L6 tube is 30 Watts, they mean the maximum input DC energy is 30 W.
    They don’t mean that the maximum amount of wasted energy due to heat is 30 Watts.
  5. peteb
    Cascadia
    I think the efficiency question is fairly well covered.
    Except for documented examples of class B.
    The last thing I wanted to say about efficiency.
    The plate dissipation ratings for tube types is the great leveler for tube amps.
    everyone knows what to expect from two 6L6 tubes. It doesn’t matter who designed or built the amp, everyone knows what two 6L6 tubes can do.
  6. elpico
    Vancouver BC
    Nope, this has nothing to with bias. Plate dissipation while passing signal is it’s own calculation. It is NOT the same as idle dissipation. Everyone keeps trying to communicate this to you, but you seem yo be ignoring it.
    No. that’s absolutely false.
    No they result from you not understanding how this works yet but making untrue statements about it anyways that conflict with what everyone else is trying to tell you. There are no “interpretations” of dissipation. It’s not a poem or abstract painting that’s open to interpretation. Physics has laws and facts.
    Most people aren’t “aware” of that because it’s absolute nonsense that you just made up. There are NOT two different types of dissipation. You’re very, very mixed up here. There are people here who are willing to donate their time to help you learn how this works but if you keep your ears and mind closed there’s nothing they can do for you.
    Wally and Bendyha like this.
  7. elpico
    Vancouver BC
    Dead wrong. They mean the maximum amount of sustained heating the plate can survive is 30 Watts.
    You’re all tangled up in imaginary nonsense about AC vs DC but Pete, THERE’S NO SUCH THING AS “AC WATTS” OR “DC WATTS”. There’s only watts. Look up what a watt is please.
  8. Bendyha
    Bendyha Friend of Leo's Silver Supporter
    Northern Germany
    Ohm Slaw - Chopped-up electronics terminology, thrown together and mixed-up. - Highly allergenic.
    robrob, Wally, Modman68 and 1 other person like this.
  9. Mexitele Blues
    Mexitele Blues Tele-Afflicted
    Westminster, CO
    Mmm. Sounds good on a class a/b push-pulled pork sandwich.
    Wally and Old Tele man like this.
  10. Old Tele man
    Does your Deli deliver?
    viccortes285 and Mexitele Blues like this.
  11. LudwigvonBirk
    LudwigvonBirk Tele-Holic
    Madison
    I am all for laws and facts, but also welcome properly supported scientific inquiry which might possibly disprove those laws or facts. To be a little more topic neutral...
    Hypothesis:
    On an lcd, as the increase of the spacing between lines of rgb 0-0-0 text displayed on an rgb 100-100-100 background expands, the distortion of the laws of physics as displayed in text will increase.
    Can anybody boil that ^ down into an equation, or cite one, that we can start with?*
    Also.
    I have not thought this all the way through. As of now, I sub-postulate that
    1) my hypothesis is not affected at all by AC-Hum.
    2) my hypothesis is not affected at all by heat.
    3) my hypothesis is not affected by time.
    4) The line-spacing-induced text distortion (of the laws and facts) may or may not be linear. [Study item]
    Bendyha likes this.
  12. LudwigvonBirk
    Madison
    *Draft:
    +Dtls = -Tr
    (As the distance of text line spacing increases negative truth increases)
  13. Old Tele man
    ADMIN please delete this post.
  14. Art VanDelay
    Art VanDelay Tele-Afflicted
    Arcata
    Things I've never said: "Hey this amp sound outstanding. It must be using electricity very efficiently"
  15. LudwigvonBirk
    Madison
    Headslap and rather brilliant point OTM! I was mistakenly attempting to introduce the current laws and facts of nature into the proposed draft equation (heat/change/distance/acceleration/distortion/CE-commodities etc), which was wrong, *my bad*.
    Draft2:
    +Zc = -Tr
  16. Old Tele man
    Bendyha and viccortes285 like this.
  17. LudwigvonBirk
    Madison
    Draft 3:
    -c =Delta-c
  18. elpico
    Vancouver BC
    Things you have said: This amp is heavy.
    Guess why that amp is heavy...
    robrob and Art VanDelay like this.
  19. Bendyha
    Northern Germany
  20. Bendyha
    Northern Germany
