Effects recommendation for solo boost please
Discussion in 'The Stomp Box' started by fenderslash, Feb 20, 2009.
  1. Tele Fan
    Tele Fan Friend of Leo's
    Louisville, Ky
    EHX LB-1 is a nice little boost and it's nice and cheap. The Vodoo Labs Sparkle Drive has a lot of knobs to play with if that's what your looking for.
  2. Paulie13
    Paulie13 Tele-Holic
    Columbia, SC
    OD pedal with low gain and high volume. I use a BB preamp for this.
  3. Manolian
    Manolian Tele-Meister
    Miami,FL
    #1 Xotic RC booster.
    #2 Klon Centaur
  4. HOBBSTER01
    HOBBSTER01 Friend of Leo's
    Ringgold, Ga.
    Tele volume knob.
  5. fenderslash
    fenderslash TDPRI Member
    Townsville, Australia
    Man, how dumb am I? I wish I'd thought of that.
  6. cletus
    cletus Tele-Holic
    Charleston SC
    Carl-- have you thought about using an od pedal on the clean channel of your amp for the crunchy rhythm and using the drive channel on your amp for the lead channel. This will give you volume/gain all the way to max volume of the amp itself.
    Or just get a Bad Bob from Robbie and all your prayers will be answered..:D
    cletus
  7. studio1087
    studio1087 Telefied Silver Supporter
    Near Milwaukee
  8. fenderslash
    Yeah that has crossed my mind while I've been thinking of possible solutions, and it's a possibility that I'm keeping an open mind about as a "Plan B". But like I said in my original post at this point my preference is that I would like to stick to the my amp's own overdrive sound for rhythm. Thanks for the help though.
  9. yanick
    yanick TDPRI Member
    montreal
    Let me humblely suggest a few options:
    -MXR Dyna Comp (compressor) they sound great
    -MXR Micro Amp (Clean booster)
    You can view good demos on you tube
    I have to say that learning to "play" with your volume knob is not as dumb as it sounds (I've been playing for 20 years now and just recently discovered the many different color of sounds you can dial with just your volume knob) I started doing that after I realised that a lot of the players I like do it. Angus Young is a master at doing just that...
  10. fenderslash
    Yeah, I know what you mean. Pete Townshend is the guy that comes immediately to my mind as an expert with the volume control. In my DVDs of old concerts he constantly gets a mountain of variation using a one-channel amp and and SG with P-90s set only on the bridge position. It's amazing to watch.
    The reason I don't want to go down that road though is that we don't have a sound guy and are a "set and forget" band when it comes to soundchecks and the PA. I have my volume knob on max the whole time because then I'll always be confident that as long as I make sure it's in that spot then I know the balance between my guitar and the band is fine, and won't have to worry that I'm suddenly getting buried in the mix, which would be harder to do if the sweet spot for my rhythm sound turns out to be something like 7.86 on the dial (a Tele dial with no numbers to add to the issue). I get by, but I'm the first to admit that I'm no Angus or Pete.
  11. yanick
    yanick TDPRI Member
    montreal
  12. diveblueflames
    diveblueflames Tele-Meister
    Yorba Linda, CA
    Visual sound home-plate pedal with their overdrive in it. Either the route 66 or Jekyll & Hyde pedal. The overdrive can gives you an 808-ish sound (with less mids) but also has more gain and more volume headroom, and an optional bass boost switch to kick your amp into gear and make some chunky sounds. It can also give you a clean to boost with. They're both probably $85 shipped on ebay. Get either one, and you've also got a good compressor or distortion thrown in free.
  13. Yoni
    Yoni Friend of Leo's
    Joliet, not the prison
    I just built a byoc OD2 with a mosfet boost and the things sounds amazing and is incredibly clean and will give you a great boost. Plus you can make yourself a great OD
  14. morroben
    morroben Friend of Leo's
    Morro Bay, Ca
    +1 I actually use a Super Duper which is two SHOs in one box, but either would work for what the OP is describing. It's the most indispensable piece of gear I own.
  15. jinx667
    jinx667 TDPRI Member
    San Diego, CA
    +1 for the SHO. Fantastic pedal.
  16. eddie27
    eddie27 Tele-Meister
    Nashville
    +1 MXR MicroAmp
  17. TelZilla
    TelZilla Friend of Leo's
    Cleveburg, USA
  18. Jahmbie
    Jahmbie Tele-Afflicted
    College Station, TX
    +1
    'nuff said.
  19. 59TweedVibrolux
    59TweedVibrolux Tele-Holic
    Nothing Better.......You're right.....those are the settings
    they were designed to be used with. NOT as an overdrive.
    KILLER Pedal :twisted:
  20. Col Ronson
    Col Ronson TDPRI Member
    Tucson, AZ
    i dont know if this would work for you but i usually use a DigiTech Whammy Bar for solos. It helps me jump octaves pretty well, tone is great, and volume boost works.
