Effects loops benefits
Discussion in 'Amp Central Station' started by Craig Williams, Sep 30, 2020.
  1. Craig Williams
    Craig Williams Tele-Meister
    Thailand
    I just got a Laney VC30 and see it has an effects loop. Have had amps with effects loops before but I always just do it the old fashioned way....guitar into pedals, lead out of the pedals to the amp input. I don't have a bank of pedals, only a Vox multi effects unit. I see my amp has an effects level knob too, must be to control the level effects have on finished sound.
    What are the benefits of using the effects loop as opposed to putting your effects straight into the main inputs of the amp?
  2. Frodebro
    Seattle
    If you're using the amps preamp for distortion (such as in a channel switching amp), having the delay and reverb in the loop (after the distortion) generally yields better results. If you're running the amp clean and getting all of your dirt from pedals, a loop is not as important.
    tonejam and xtelesquirex like this.
