Effects IN the guitar?
Discussion in 'Tele Home Depot' started by oceanblue, Nov 19, 2019.
  1. oceanblue
    oceanblue Tele-Meister
    So for you tech savvy builders, it is actually possible to add an effect, say reverb (or any other effect), directly into the guitar? Perhaps after tone/volume, in the signal chain in the guitar, before going to output, having a reverb (or whatever) knob to adjust? Has it ever been done? Can it? If it can't, why?
  2. glenlivet
    glenlivet TDPRI Member
    Marco.......Polo......
    Can it be done.....yes. I *believe* GFS makes some active electronics to fit inside a guitar cavity.
    *should* it be done .....probably not.
    All the effects require some sort of power...ie: batteries.
    When do batteries die ? .... when you need them the most.
    It's been done/tried before....and as far as I know the general consensus is..... it works like s****.
    But hey.....give it a try ! What's the worst that could happen ??
  3. LunarSlingShot
    LunarSlingShot Tele-Meister
    Oklahoma
    Your battery dies during the biggest show of your lifetime, opening for your favorite band....
    or at band rehearsal. Whichever...
    crazydave911 and Moriarty like this.
  4. matmosphere
    matmosphere Tele-Holic
    earth
    Sure, companies have tried do to that in the past. Electra did it in the late seventies, danelectro did in the nineties.
    what I would say is that you better be darn sure it’s a sound you’re happy with cause it’s more work to change than just swapping a pedal. AND the idea would be best suited to fuzzes and overdrives that don’t need a lot of juice to run. Throwing a delay, reverb or modulation would just burn through batteries faster than you could recharge (or heaven forbid replace) them.
    I suppose you could look into some kind of lithium battery, like a phone or a computer, but it would probably add a decent amount of weight to have one that would make it worthwhile.
  5. oceanblue
    I doubt I'll be doing it with any build myself, I was just curious. Knowing it can be done, I'm surprised some overseas builders doesn't make one with a few effects, but maybe too small a market for it.
    I also wasn't sure of the size of the electronic/computer board/component that actually does the effect either.
    I guess seeing amps with a bazillion effects, seemed reasonable to put one or two common ones, directly into a guitar body, to play through a nice clean amp of choice. At least would allow you to easily adjust those two effects right on the guitar as you play.
    As for battery, doesn't any guitar or bass that is not passive have the same issues?
  6. matmosphere
    earth
    You’d also want to change the jack wiring to cut the ground to the effect when a jack isn’t plugged in so that it isn’t using battery all the time.
    tubelectron and nojazzhere like this.
  7. oceanblue
    Interesting points, and appreciate the input. I wasn't aware of the varied differences in power usage from pedal to pedal depending on effect. I suppose for changing effects, a module design that could easily be swapped would be the ticket, as opposed to soldering in new electronics for a change.
  8. Jim_in_PA
    Jim_in_PA Tele-Holic Ad Free Member
    SE PA near New Hope PA
    Here's one with built in effects; portable, self-contained when you want/need it to be and has a chargeable battery rather than replacements. Not wood, either, but that's a different subject. It actually sounds really nice.
  9. rangercaster
    portland, or
    It's been done ... Guitarists like to stick to tradition, so they didn't buy it ...
    Steveinthesticks and matmosphere like this.
  10. fendrguitplayr
    fendrguitplayr Poster Extraordinaire
    Greater Boston
    The old Vox teardrop shaped guitars had some effects in them.
  11. mistermikev
    mistermikev Tele-Holic
    phoenix
    no different than an active preamp. I wouldn't put a reverb, delay, or modulation type effect because they burn up 9v like nothing but I've put lpb, stratoblaster, and sho in a guitar. I usually install a push/pull so they can be true bypassed... in case I don't want them on or the battery dies. lately I've been designing pcbs that mount on a push/pull... sort of makes it more modular. think I posted a pdf of one on here, and if not def at projectguitar.com in case you want to have a look.
  12. blowtorch
    Wisco
    I have a Fernandes Vertigo FX
    ...and a Line6 Variax
    ...and an Ibanez Kaoss Pad RGKP6 guitar
  13. Obsessed
    Montana
    The Epiphone Slasher FX had chorus and distortion built in. Yup, 9 volt battery. IMG_4169.JPG
    nojazzhere and blowtorch like this.
  14. blowtorch
    Wisco
    Also my First Act VW Garagemaster has a built-in boost
    Macrogats, matmosphere and nojazzhere like this.
  15. nojazzhere
    Foat Wuth, Texas
    All the comments so far make sense, but the reason onboard effects never appealed to me is that it might not be the right effect for you. How many DIFFERENT overdrives, choruses, fuzzes, etc. pedals are on the market? And everyone of them have their fans. It just doesn't make sense to limit yourself to what a guitar maker decides you get to use. Many of us here are always changing pickups, bridges, even necks on our guitars. Changing an effects pedal is "easy-peasy".......;)
    cyclopean likes this.
  16. blowtorch
    Wisco
    I've always wanted one of these danoblasters, with built-in fx
    crazydave911 likes this.
  17. Chiogtr4x
    Manassas Park, VA
    In the late '70's in College, a buddy brought over ( to my apt.) A '60's VOX Hollowbody ( kind of like a full hollow 335 size, bolt on neck ) for me to check out.
    It had effects slide switches ( maybe small knobs too) around the perimeter of the guitar's top ( some may have been paired with different settings, some just ON/OFF:
    FUZZ
    TREMOLO/ REPEATS
    ECHO/DELAY
    ' E NOTE' TUNER - ( produces an audible E note thru amp, so you can tune up!)
    Bigsby style Whammy
    AND a spring loaded ( heart shaped lever) palm bar near bridge you pushed on to activate a WAH-WAH filter!
    ** I barely knew how to play then, I could have garagey fun with this guitar now!
  18. Bob Womack
    Bob Womack Tele-Holic
    Between Clever and Stupid
    In the '70s, Electra had an epic crash and burn with the MPC line for all the reasons mentioned above.
    Bob
  19. Mike Simpson
    Gilbert, AZ (PHX)
    I have this Kay Effector guitar. The effects need a little work.
    Brian J. and crazydave911 like this.
  20. Peegoo
    Peegoo Tele-Meister
    The Godwin Guitorgan was a big jazzbox type of guitar with an organ built into it. Yes, it weighs about 20 pounds. Look:
