Commodore 64
So I've built an amp here, kinda inspired by a few things, including my never having built (or heard) a paraphase PI. Taking a page from Dr. Z (and fred mertz, where are you fred?), I used ultralinear taps on my OT, an Edcor GXPP15 and an EF86 as a preamp tube.
I've attached the schematic.
1. I added the 470k between C7 and volume pot. Much better volume sweep with clean headroom.
2. There's 60Hz hum, doesn't change in volume with the knobs. More than any other amp I've built.
3. Suspecting power tube mismatch (all my 6BQ5 are used/tested). I did some tube rolling. Seems like whatever I do, there's always 6-7 mA difference. And that difference increases, the longer I leave the amp on. This behavior follows the tube socket, not the tube.
4. Amp sounds great, except for the 60hz hum, BTW.
5. Best I can tell V3 is drawing some grid current. It got up to 1.8V before I turned it off.. It's not leaking coupling caps (swapped out and tested 'em). So maybe something to do with the UL taps or OT?
6. Is there any other way this behavior could happen? Would this be a sign that my PI isn't balanced?
Here's some voltages:
V1 (EF86)
1: 173
3: 3.2
6: 105
V2 (12AX7)
1: 176
3: 1.26
6: 179
8: 1.26
V3 (6BQ5)
2: 1.8v (and climbing)
3: 10.8
7: 311
9: 308 (UL tap to OT)
V4 (6BQ5)
2: 60mV
3: 10.8
7: 311
9: 308 (UL Tap to OT)
Still debating on whether to add the MV. The Pro jr. trick of diming the amp and using the guitar volume seems to work pretty well.
Build pics:
Built some cabs. Speaker from an old pine shelf, the other a dovetailed flat-pack I had made at an amish "drawer" building company. An amp cab can be a glorified drawer in their eyes. And I can't buy non-cupped pine boards for the price of the poplar "drawer" ('bout $19). Plus, unlike my cabs, they are always square!
And a little closer to done, with some tolex.
V1 (EF86)
1: 173
3: 3.2
6: 105
V2 (12AX7)
1: 176
3: 1.26
6: 179
8: 1.26
V3 (6BQ5)
3: 10.8
7: 311
V4 (6BQ5)
2: 60mV
3: 10.8
7: 311
Build pics:
