ECC99 Reverb Driver
Discussion in 'Shock Brother's DIY Amps' started by Seabstudio, Nov 15, 2019.
  1. Seabstudio
    Seabstudio NEW MEMBER!
    France
    Greetings !
    I don't know if I can post here for this question
    I already build a standalone spring reverb with a transformeless driver for tank for a studio use ( I put a steup transformer and I have 12Vp-p at the tube grid
    It work good, but I want to drive more the tank and don't know witch values I need to tweak arround the Tube
    I follow the Valve Wizard recommandation ; ( See middle / end of this page )
    http://www.valvewizard.co.uk/reverbdriver.html
    Originally he drawn shematic for ECC82 , but he say " A larger triode like an ECC99 or even a triode-strapped pentode might be used on its own "
    But I think values can be ajusted ...if soemone can help :)
    Thanks in advance
    datasheet
    https://www.jj-electronic.com/images/stories/product/preamplifying_tubes/pdf/ecc99.pdf
