beyer160
All guitars that can have Bigsbys, should have Bigsbys.
That's not how any of this works...I’ve owned some guitars with a roller bar Bigsby and I can say that very steep break angles behind the bridge will defeat the roller action. The down tension basically keeps the roller from rotating, the bridge is forced to rock and then the string gets snagged. One guitar (Gretsch Pro Jet with mini HBs) could not stay in tune and the Bigsby was too stiff. The break angle was at the extreme end for a TOM, where basically a string or two rests on the bridge frame. I hear what you’re saying though, even though break angle is always a thing to consider.
I think I should clarify - the original thread was an inquiry as to whether I should pursue the T64 with a Bigsby or one without.
Not feeling skilled enough to install one.
Appreciate the responses.
It is difficult to address your question involving "inherent tuning issues" without explaining those issues, and possible solutions or improvements. Good luck with your choice.I think I should clarify - the original thread was an inquiry as to whether I should pursue the T64 with a Bigsby or one without.
Right on @Boreas, I know you get it. All bridges rock with a vibrato, and in a TOM set up, the post 'slop' is necessary for a 'good' Bigsby setup, at least for players who are just using it mildly. I haven't met a TOM that was designed to rock however, most people are focused on 'locking' the bridge body to the post. This really doesn't stop a bridge from moving--the string start pushing/pulling at the post threads, and eventually get snagged on a non-rolling saddle.Much depends on how we wiggle I use the Bigs often, but subtly. So I prefer a smooth, soft wiggle made possible with a squishy spring. Heaven with a minimum of break angle.
What many people likely don't know is that T-O-M some bridges are often designed to be sloppy on the posts and will rock sufficiently for mild wiggling. If you look at the underside, the many designs come to a soft V that ensures it will rock if there is enough slop in the post. The strings stay planted on the saddles and the bridge top rocks - and things miraculously stay in tune.
But if one wiggles their stick with gusto, the strings slip and you will often lose tune unless you include countermeasures to bring it back after a dive - usually just a quick flip of the handle upward to get the strings centered again. The roller replacements usually eliminate the need for this.
But when I can, I simply use Fender Jag/Jazz bridges, minimize the break angle, and play in tune all day long. Bliss.
That guitar was badly designed to use a B5, and no it never worked well, even with a roller bridge. Too much break angle behind the bridge. I sold it and eventually got a real Duo Jet w/ B3 many years later. No tuning issues with the later, and no roller bridge either.That's not how any of this works...
Ditto. Electromatic was much-improved with a B3. Left a couple holes which I left. She's a sweet wiggler now.That guitar was badly designed to use a B5, and no it never worked well, even with a roller bridge. Too much break angle behind the bridge. I sold it and eventually got a real Duo Jet w/ B3 many years later. No tuning issues with the later, and no roller bridge either.
