Earth Sound Research amp needs some love
Discussion in 'Amp Tech Center' started by rojo412, Aug 8, 2019.
  1. D'tar
    D'tar Friend of Leo's
    WNY
    black to ground
    red to power tube pin 5
    get that # and the rest
    p1
    p2
    p3
    p4
    p5
    p6
    p7
    p8
  2. D'tar
    WNY
    Rojo,
    Now that you have B+ to the filer capacitors you need to be checking and draining the caps before you are going inside the chassis. Any work should be done with the amp unplugged and caps drained.
    Taking voltage reading with amp on. I assume you have read the safety concerns and will apply them to all the steps that are suggested. Be careful.
  3. rojo412
    rojo412 TDPRI Member
    Cleveland, OH
    I'm definitely being as cautious and careful as I can be. And I'm asking what may sound like dumb questions to people who know what they're doing, but I'm still new at this, so I appreciate people bearing with me.
    TO VERIFY: Testing the points requires the power to be on and careful probing, but before I solder is when I need power off, caps drained, amp unplugged. Correct?
    W.L.Weller and D'tar like this.
  4. D'tar
    WNY
    Correct...
    Black lead secured to chassis
    One hand behind your back
    Turn on amp
    probe pins with red lead
  5. rojo412
    Cleveland, OH
    With the bias dialed down to lowest negative, I get it at -63.5 VDC.
    Inserted tubes, flipped back on, no limiter light, tested again. Both sides (tube sockets) are the same readings:
    1&2: 0vdc
    3&4: 13ish vdc, then drops steadily
    5: -62.8 vdc
    6: -65.3
    7&8: 0vdc
    Does it matter if standby is on or off at this point? It's been in standby for everything.
    And when I turn the amp off, I unplug it and then test the caps, which are steadily dropping to 0 the longer I wait.
  6. D'tar
    WNY
    put the standby in play position
    you have no plate voltage P3 recheck
    P2 and p7 will be vac reading
  7. rojo412
    Cleveland, OH
    2 & 7: 3.2 vac.
    Getting spotty readings on p3, blips but then nothing.
    D'tar likes this.
  8. D'tar
    WNY
    You did reinstall the O/T right?:)
    Where is the O/T center tap connected and what is the voltage there.
    Edit: should be connected at the standby switch.
    What is the voltage DC on either side of the standby
  9. rojo412
    Cleveland, OH
    Here's my earlier findings on the OT:
    Red (tap, I'm assuming) connects to the standby. I was trying to get a reading there, but it's wonky. It will show voltage, then drop or just cut out.
    That said, there's a grey wire connected there as well, which goes to the other capacitors.
  10. D'tar
    WNY
    With standby in play position does either side of the switch show a good voltage reading?
  11. rojo412
    Cleveland, OH
    No, not a consistent one. It will get some kind of reading then either continue to drop or just say nothing.
  12. D'tar
    WNY
    Keeping the standby in play
    Do you still have B+ at the orange wire on the board?
    We need to be able to determine at what point in the schematic we lose B+
    Starting at the board follow the orange wire and take readings at every connection up to the standby
    a few good pics of this area would be good. Not real close
    What kind of meter do you have.
    Try putting the tubes in and see if the bulb limiter is still good. Do you have sound with a guitar plugged in. Some meters have difficulty reading higher voltages. Not saying you need a new one just a thought.
    Wally likes this.
  13. rojo412
    Cleveland, OH
    Okay, my bad, I had the meter set to the wrong DCV number.
    - Checked B+ at orange, 518 DCV
    - Checked the #3 pins, 518 DCV with standby in PLAY mode.
    - The tubes have been in since I turned the bias down. The limiter hasn't lit since that diode was removed.
    - I've gotten a few "POPS" from the speaker when checking points, but nothing consistent there.
    - Haven't plugged a guitar into it, no. Was afraid to try that yet.
    Wally likes this.
  14. D'tar
    WNY
    Try it!!!
    It probably won't sound good on the limiter but we will know if it is passing signal.
  15. rojo412
    Cleveland, OH
    It is making noise through the speaker. I started with the cable and just tapping it, which made noise, then plugged in the guitar and I got some signal as well.
  16. D'tar
    WNY
  17. rojo412
    Cleveland, OH
    Off: 1.5 ohms on both.
    On, play mode (standby off), 6 mV.
  18. D'tar
    WNY
    Adjust that pot until you are around 20mv, Then recheck plate voltage and cathode mv.
    read through the how to bias link above. Use the bias calculator to keep you in a safe place. I may recommend getting to about 60%. You can go a little higher. Those resistors should be 1ohm 1% resistors. The mv reading translates equally to mA. Do some reading and play with the bias. I have a football game to get to! have fun. Good job getting this going.
  19. Preacher
    Preacher Friend of Leo's
    Big D
    @rojo412 I have nothing to offer as you have the best amp minds working with you on this project.
    But I wanted to say one thing, way to go! You are making progress and I promise some of this stuff will start making sense. Keep it up and you will be like @robrob and @D'tar before you know it!
  20. rojo412
    Cleveland, OH
    @D'tar You rock! Thank you so much for helping me here. I hope you have a great time at the game.
    - Plate voltage is now 500 VDC
    - Cathode is pretty close to 20 mv.
    I'll definitely be reading and re-reading the info on that site.
    @Preacher I'm certainly hoping that some day, I can be a fraction as good as these guys.
    Preacher likes this.
