E53 Master Volume Issue
Discussion in 'Amp Tech Center' started by mkerlin, Feb 18, 2020.
  1. mkerlin
    mkerlin TDPRI Member
    Allentown, New Jersey
    This is my third kit (Champ, HP Twin were my others), and I am having an issue I am completely stumped on. I installed a Pre Phase Inverter Master Volume and I hear output from both normal and bright channels with the master volume pot all the way down. Also the MV pot doest really work for the first 10 deg or so and then pops up all of a sudden. I attached a few images. Any helpful troubleshooting suggestions would be appreciated. IMG_1858.jpeg IMG_1859.jpeg IMG_1860.jpeg
  2. dogmeat
    dogmeat Tele-Afflicted
    Alaska
    double check the pot's ohm value and the taper (or not). I don't know that build but it should probably have audio taper
  3. mkerlin
    CTS 1 megohm audio taper
  4. separateness
    separateness TDPRI Member
    South Carolina, United States of America
    I am not familiar with this amp but I take it you put a 1MΩ pot between the two 12ax7 triode stages and you put it in place of the 1MΩ fixed resistor? A drawing of your modification would be helpful.
  5. nathan5782
    nathan5782 TDPRI Member
    Sacramento, California
  6. OldPup
    OldPup Tele-Meister
    Charlotte, NC
    Why is one leg of that resistor floating between the mojo dijon and the black capacitor in the second photo?
    Edit: it's also visible in the third photo
  7. mkerlin
    I lifted just the one side instead of removing it till I was satisfied with the mod without thinking that it would make a difference?
  8. mkerlin
    Mine is the same unless I made a mistake? I didn't use the same color plan. Black (middle photo) goes to 22nF on the pot side of the board.
  9. mkerlin
  10. nathan5782
    I couldn’t tell if the black went into the blue heat shrink with the other wires, and came out as the ground out of the red heat shrink. The resistor with the lifted leg is just the bypassed 1M. I’m assuming this was a functional amp before the master volume mod. I’m guessing maybe some wire is contacting somewhere, I’ll look at mine later it’s about the same except I used a separate coax shield wire for each lug 1 and two of the pot I think.
  11. Jon Snell
    Jon Snell Tele-Meister
    Jurassic Coast. UK.
    If you connect the volume as shown, you will always have volume because your common goes to the bottom half of the phase splitter and doesn't shunt the signal, it will always produce sound.
    If you wire the pot as it should be with the ground going to ground not the hot end of the 56k as that is still signal, place a 22n capacitor between the wiper and pin 7 then fit a 1M resistor from pin 7 to ground. 5e3_Pre_PI_Master_Volume_Schematic.png
    separateness likes this.
  12. mkerlin
    Thank you Mr. Snell. I am a novice/hobbyist so please bear with me. I want to understand your recommendation clearly before I start making changes. First your recommendation differs from the schematic you posted which is how I wired it? I marked up a diagram (which I am more comfortable working from) based on your description. Is this a correct representation? If not could attach a marked up schematic? Also I assume I reconnect the 1M resistor from the 56k that was removed? Thanks for your help.
  13. robrob
    United States
    Why do you need no signal with the MV turned full down?
    Some people do report a rather non-linear volume effect with this master volume. I believe variations in 12AX7 tubes accounts for some of this.
    Paul G. likes this.
  14. mkerlin
    I don't. I was just confused by it as it is my first deluxe build and I thought maybe I had assembled something incorrectly. I tested the MV pot today and determined that the taper was very flat for the 1st 30% and I had another that was much more gradual so I switched them and it is much better.
    I did install the 3-way NFB mod and its great, but at about 50% on the MV (which is pretty loud) I'm getting feedback. Is this typical? - and thanks for the post.
  15. robrob
    United States
    No, the feedback is not typical. I would try switching the output transformer primary wires.
    King Fan and mkerlin like this.
  16. mkerlin
    That did the trick. Its an entirely different amp now. I had the same issue with the HP Twin I built but it was evident the second I turned it on. Thanks for the help.
    robrob likes this.
  17. robrob
    United States
    Sweet, I'm glad you got it sorted out.
