Dynakit 70 in the house
Discussion in 'Shock Brother's DIY Amps' started by peteb, Aug 1, 2020 at 6:13 PM.
  1. peteb
    peteb Friend of Leo's
    Cascadia
    2E57787E-049A-4E34-AB8B-30D775314603.jpeg It only took 31 years, she’s mine.
    Now what do I do with it?
    All I really want to do is see if the tubes have the right voltages and then put some signal thru it.
    9833E2E5-A59F-4D77-A8B8-32B10A0EB814.jpeg 1F9E86B2-E51A-4B71-969D-74600D2A60A4.jpeg 7B0067B9-76D8-41F4-8C69-48B01D0D6229.jpeg EBCBB305-00B5-4610-8EBF-6EF8D1F48E0A.jpeg A7DF5B70-4564-45C2-8941-C2B91F9F38B5.png
  2. schmee
    Cool.
  3. String Tree
    String Tree Doctor of Teleocity Ad Free Member
    Up North
    Turn up some Deep Purple!
    rangercaster likes this.
  4. rangercaster
    Knoxville TN for now
    What speakers are you running ???
  5. awasson
    awasson Poster Extraordinaire Gold Supporter
    Vancouver
    Such a nice amplifier. Just a Classic. I’ve got something in my office my dad built that’s really similar to that and of the same era. I’m running a pair of Advent speakers with it.
    B0FE1D17-036B-4DDD-93C5-42EB611999F3.jpeg AB27B7C4-F8CE-4447-8C0F-4FEE0415A80A.jpeg 374D7964-D097-4C3A-AB68-A8AD6C8BD71D.jpeg
  6. Bill Moore
    Bill Moore Tele-Afflicted Silver Supporter
    Silver City, New Mexico
    I bet you enjoy it!
    I have a mk iv that I found at the dump years ago, minor repairs, and it sounds great. I used to use it for practice, running an mp3 player in, and one of my EV floor monitors out. Plenty of power, and sounds fantastic!
    awasson likes this.
  7. muscmp
    muscmp Tele-Afflicted
    california
    i have two st70s that i've refurbed. used cap can mentioned above and replaced electrolytics including the bias cap. i run them in mono with mcintosh mx110 as the front into two jbl 4311s.
    play music!
    Ricky D. and awasson like this.
  8. peteb
    Cascadia
    I’m checking things out slowly and carefully.
    The quad of old Millard EL34s are drawing current, around 100%. MPD in fixed bias, with no red plating.
    I only have dummy loads hooked up to the outputs so far, so no idea of noises or hums etc.
    The plate voltage on the EL34s is 390, with -30 fixed bias.
    Should that -30 V be more like -40 V?
    Here is the problem going forward.
    All four grids of the two pre amp tubes (this is only the power amp) have high voltage 300+ DC.
    You can see on the schematic that the first plate connects directly to the next grid with no coupling cap. There would then be high voltage DC on the grid.
    How can that work?
  9. David Barnett
    Bias for the Stereo-70 is easy, start with the manufacturer's recommendation, measured 1.56V across the 15.6 ohm cathode resistors. They gave you handy test points right there on the octal sockets at the front of the amp.
    After everything is up and running feel free to play with that, but it's a convenient starting place while you're troubleshooting.
    peteb likes this.
  10. elpico
    elpico Tele-Afflicted
    Vancouver BC
    Direct coupling one tube's grid to the previous plate happens all the time. See any Marshall/vox tone stack driver for example. That said, I don't think the input grid should have high voltage. Are you sure you're not measuring the screen grid?
    peteb likes this.
  11. peteb
    Cascadia
    David,
    Now I get it.
    I thought the 1.56 V was the pre amp tube bias, because 1.5 V is a typical pre amp tube bias, and the preamp tubes are on the PCB which I know has the bias circuitry, and I now see the front panel says pre amp power by the 1.56 V.
    But, yes, pin5 of each power tube has a wire going to one corner of the PCB. Maybe that is the signal from the preamp tubes? But either way, turning the screws definitely changes the fixed bias on the power tubes, one screw per pair.
    Elpico,
    Thanks for confirming high voltage DC can be on the grids. The first grid has it too, the schematic shows the high voltage DC going to plate 1 also connects to grid 1 thru a resistor. No current flow thru the grid means no voltage drop.
    I adjusted the bias from -30 V which I believe it was purposely set at. The extent of the range leaves the bias at -35 volts which is still not cold enough. One EL34 still idles at 104% MPD.
    They run these hot. 1.56 V at the bias test point means 50 mA per EL 34.
    One of my EL34’s is closest to 50 mA. It is at 52 mA, 410 on the plate for 85% of the MPD of 25 W.
    Once the bias was lowered all the down, I connected a test speaker to the right side, dummy load still on the left.
    It made amp sounds, clicks from the input, no hum (although there is about 45 VAC on the chassis) so I put a guitar signal into the input of the power amp.
    One 7199 appears non op. I put the left 7199 on the right side and signal got thru to the speaker.
    I was surprised, the guitar had to be turned up high to get thru at all, and then it was less than 1 Watt output and extremely clean and cold sounding. That makes sense because it needs the preamp to boost the signal.
    Now I will look at the pre amp. I assumed that there are no tubes in the pre amp because the box has no vents.
    Just now looking closer there are some vents on the back on one end.
  12. David Barnett
    There are four 12AX7As and a 12X4 in the preamp. If you're lucky the 12AX7As will all be Dynaco/Telefunken tubes.
    The sockets on the front of the Stereo-70, in addition to providing a bias test point for the amplifier, were there to provide power for a pair of the original Dynaco PAM-1 mono preamps, which did not have internal power supplies. The stereo PAS-2 preamp you have connects normally and does not require the external power source from the amp.
  13. David Barnett
    Also I would recommend replacing the selenium diodes with silicon.
