I'm looking to buy a Duplicolor primer to use under Duplicolor Perfect Match spray cans and I've found the following different types:
The 3rd one above is probably the best choice as it is from the same Perfect Match Duplicolor line, however it's 8 ounces only (vs 12 ounces for the first two) and is very expensive.
Can I use any of the first 2 above under a Perfect Match solid color?
