duo sonic pickups out of phase?
Discussion in 'Just Pickups' started by 2after909, Sep 24, 2020.
  1. 2after909
    2after909 Tele-Holic
    brooklyn, ny
    Basic wiring question. I should know this, but I don't. I suspect the two single coil pickups in my parts duo sonic are out of phase. It was wired with an on-off-on switch, for series wiring in the middle, but it sounded honky and thin. I thought my friend who wired it for me had messed up that wiring, so today I put in a les paul style toggle and wired it for parallel in the middle position. Still thin and honky. I guess the pickups are out of phase. The neck is a vintage fender mustang and the bridge is a modern Novak replacement. Both pickups have white hot leads and black ground leads. If I wire one of the pickups so that the black is treated as the hot and the white is the ground will that fix the problem? Thanks
    Boreas likes this.
  2. BorderRadio
    BorderRadio Doctor of Teleocity Silver Supporter
    Phoenix, AZ
    Yeah, at first read it seems like the Novak wires need to be flipped at the switch as you said.
    Boreas, 2after909 and Danb541 like this.
  3. Boreas
    Boreas Tele-Afflicted Silver Supporter
    Adirondack Coast, NY
    You know what they say about assumptions...
  4. 2after909
    brooklyn, ny
    Yep, that fixed it. Thank you. Now that I know that's the deal I'm probably gonna go back and wire it for the Mike Bloomfield series middle position thing.
    BorderRadio and Boreas like this.
  5. BorderRadio
    Phoenix, AZ
    That's the best thing about Duo Sonics and certain Danelectros...
    2after909 likes this.
  6. archetype
    archetype Fiend of Leo's
    Williamsville NY
    Just reverse the leads on one pickup and see what happens.
