Duncan BG-1400 wiring detail
  • Thread starter mike58
mike58
Hi
A friend of mine is dropping in his Tele for a rewire, it has a BG-1400 bridge p/u fitted.
As this is a stacked p/u with high DC resistance would it be reasonable to use a higher value pot or as the stacked coils tend to fight each other and sound like a lower wind just use 250k.
I can’t find any SD info for recommended pot values.
I have seen folk use up to I Meg with this unit, but that was on an Esquire build, this wiring has to work with a standard single coil neck p/u as well.
Secondary point : as this is a 4 wire p/u I was going to wire it in coil-split mode when combining with neck single coil ( to improve balance) BUT as it’s a stacked single coil is this a good idea, do stacked coil splits work the same as humbuckers ? .
Thanks
Mike
SPUDCASTER
Grangeville, Idaho
Have you tried the SD forum?
You don't see much these days here about the BG-1400. Just on occasion.
Did you try a search here?
I used a 250k with an SD Hot Stack and it worked just fine.
If you pull up the wiring diagrams on the SD site. Put in 2 pickups, singlecoil neck, humbucker bridge and 3-way blade. You get a diagram with a coil split bridge. They show a 250k volume and tone pot.
The 4 wire BG shouldn't be any different wiring wise than a standard bucker. It's just stacked.
mike58
Hi, agreed 250k is the way to go. Apparently stacked single coils sound poor when coil split as well so I’ll leave that option out.
Thanks
No more information needed.
Mike.
hamerfan
Germany, Bavaria
Hi
Thanks
Mike
Its just a matter of taste. If it sounds too dark and muddy, you need a 500k or better a 1meg. If the neck becomes to bright, you can add a parallel 500k resistor on the switch to the neck seeing a lower resistance and loosings highs, while bridge works fine with the 1 meg.
Sax-son
Three Rivers, CA
I called Seymour Duncan a while back asking the same question. They recommended the 250K pots. I used the Eldrige cocked wah wiring harness and it sounds really good. If connecting with a neck humbucker, you might as well go the 500k route. Makes things much more simple.
