Duesenberg Tremola Tremolo Install Question
Discussion in 'Other T-Types and Partscasters' started by kylebrenn, Nov 15, 2019.
  1. kylebrenn
    kylebrenn TDPRI Member
    Indiana
    Probably a really dumb question, but I’m kinda a dumb guy with some of these things, so here it goes.
    The Duesenberg Tremola I just bought has a few small felt pads on the back of it. Am I supposed to leave those on or take those off to install it on my Partscaster?
    Thanks for the help in advance!
  2. brookdalebill
    Austin, Tx
    I would assume the pads are there to keep the tremelo from marring the guitars finish at contact points, no?
    kylebrenn, Telecentric and Shuster like this.
  3. SixStringSlinger
    SixStringSlinger Friend of Leo's
    Space
    Bigsbys have those, as well. I always assumed it's for the reason @brookdalebill mentioned, but it's a little odd given that the trem is screwed into the guitar; you'd care about marring the finish (presumably in case you ever want to remove the trem), but not about some huge screw-holes? Although not every type of Bigsby screws into the guitar, and I have no idea how the Duesenberg works.
    Anyway, I took the felt pads off of my Bigsby, partially due to some (quite possibly woo-woo) notion of "greater contact", but also because it went on a ratty old Squier body and I'm committed.
    kylebrenn likes this.
  4. kylebrenn
    Indiana
    Exactly my thought. The Duesenberg Tremola screws straight into the guitar body, so yeah, same thing with the screw holes. I think they do make a “plate” like the Vibramate to keep from needing to screw into the guitar body, but the only one I can find uses a 3 screw bridge and my body has 4 so it wouldn’t work.
  5. kylebrenn
    Indiana
    But does that matter if it’s putting screw holes in it anyway?
  6. brookdalebill
    Austin, Tx
    The devices sometims move/shift, resulting in marring of the finish.
    I can think of no other reason for the felt pads.
    I agree a Vibramate type of mounting platform would be better..
  7. SixStringSlinger
    Space
    This is something I hadn't considered. So concerns about finish-marring are relevant even if you have no intention of removing the unit.
    kylebrenn and brookdalebill like this.
