SGE1967
I'm considering changing out the Bigsby Arm on my Tele. Does anyone know if the Duane Eddy and Chet Atkins arms are a good fit on a B5?
I don't know why not. The Chet Atkins position can be adjusted somewhat as well by rotating it in its bracket. This was a replacement arm. Swapped B5 for a B3V. I tend to pick/strum over the neck pickup, so the slightly longer handle was not an issue. With a B5 you will typically have more wiggle room to move the frame away from the bridge if that is an issue.I'm considering changing out the Bigsby Arm on my Tele. Does anyone know if the Duane Eddy and Chet Atkins arms are a good fit on a B5?
