Dual Self Split ECC99 amp stops humming when I measure the cathode Voltage
Discussion in 'Shock Brother's DIY Amps' started by reggiepe, Oct 14, 2020.
  1. reggiepe
    reggiepe TDPRI Member
    Pennsylvania
    I built a dual 12BH7 Self split amp...a little info troubleshooting the build is here:
    https://www.tdpri.com/threads/mojotone-studio-one-inspired-build.1050572/
    I know I can run ECC99's (with the cathode resistors changed and reflected impedance adjusted, of course) in this amp as well. But when I swap the 12BH7's for ECC99's I get a loud hum. That hum stops completely when I touch the positive probe to the shared cathode of V4 to get a voltage reading. Anyone ever experience this before? I don't mean with ECC99's, but with anything that was cathode biased.
    I have attached the schem for the Mojo Studio One inspired build
  2. andrewRneumann
    andrewRneumann Tele-Holic
    Cincinnati, OH, USA
    Hello Again :cool:,
    Does the hum get better/worse when you measure V5?
  3. LetItGrowTone
    LetItGrowTone Tele-Meister
    U.S.
    Just guessing that grid stoppers on the top half of each pair would stop this, maybe even on only one of them.
  4. dan40
    dan40 Friend of Leo's
    Richmond Va
    Perhaps a small value ceramic snubber cap would help. They are not normally used for hum issues but it would be easy to try.
  5. Lowerleftcoast
    california
    That is what I thought. Touching with the probe is probably introducing some capacitance. Also, it may not be hum as much as oscillation heard as hummm.
    Although, a grid stopper can solve issues as @LetItGrowTone opined.
    dan40 and LetItGrowTone like this.
  6. sds1
    sds1 Tele-Afflicted
    Orlando, FL, USA
    I've killed a particular hum in a particular amp with DMM leads before, I want to say on the PI grids...
    At the time I posted about it and nobody had a clue why the DMM would be able to do such a thing. Only speculation.
    Never seen a good answer for it.
    Anyhow, I would say ignore the part about the DMM. Red herring. You got a bad ECC99 that's my guess, I would recommend you start there. The ECC99 shouldn't hum in a circuit that wasn't humming otherwise. It needs no special configuration compared to the 12BH7. It should "just work" as you already knew.
    Lowerleftcoast likes this.
  7. reggiepe
    Pennsylvania
    Sorry, got behind on my forum posts
    Stays the same when I measure the other cathode.
    Where would the snubber cap go? across the cathode?
    I did assume that the ECC99 was bad. but I can run the each one individually and they seem fine.
