Dryer Repair
Discussion in 'Bad Dog Cafe' started by dented, Aug 25, 2019.
  1. dented
    dented Doctor of Teleocity Gold Supporter
    I-10 East onramp
    I have a Whirlpool Duet Dryer. All power is there and the panel lights up. Interior light comes on when you open the door. Power switch lights up but when you push the start button you hear a click and nothing happens. The barrel will spin manually but not sure how much belt resistance there should be. Start with the belt? If the belt is there and properly running through the motor assembly what next?
  2. D'tar
    D'tar Friend of Leo's
    WNY
    Look for your manual. You should be able to put it into diagnostic mode and retrieve a fault code. I have a duet also. The door switch failed on mine. Pretty sure the light still worked though. If you are handy, pull the codes they are fairly easy to repair
    KG7IL and dented like this.
  3. wabashslim
    wabashslim Tele-Afflicted
    Sonorous Desert
    Can you hear the motor running? Any faint humming, buzzing, etc? Some safety switch (like the open-door switch) that's keeping it off? Worked OK before? Overload protector/fuse/breaker/reset button? I dunno, the first & only dryer I opened up & fixed was from the 80's, the appliance version of a Tweed Champ compared to a Cyber-Twin.
    dented likes this.
  4. 24 track
    kamloops bc
    these things have thermal sensors all over the place and if one is gone or the heating element is toast the unit will not fire up, my last one I had ( after major diagnostics) has a 50cent diode and resistor combo blown on the computerized control board , the problem was the the control board had 2 inches of clear epoxy covering it and no way to access the electronics .......
    the solution it cost me 70.00 for the service call to the house and 1400.00 for a new washer and matching dryer ( for some reason they stopped making my unit and the controll board was no longer available ,go figure)
    dented likes this.
  5. fendrguitplayr
    fendrguitplayr Doctor of Teleocity
    Greater Boston
    It sounds like a bad switch (actuator?).
    dented likes this.
  6. rangercaster
    Knoxville TN for now
    Could be a belt issue ... Pull the back panel and have a look ..
    dented likes this.
  7. jimbo735
    jimbo735 Tele-Afflicted
    Michigan
    Are you going to troubleshoot it,if so as mention check switch,thermal sensors and heating element,if there shot ,thermal sensors, theres usually two types and are on line and get a few of each,if it comes down to the brain check prices then check, the website Circuit board medic, they will troubleshoot and have it back to you in three days for 99 bucks,alittle more with shipping,I found no bad reviews.They fixed my Maytag front loader brain,and they back there work.Good luck!
    dented likes this.
  8. Obsessed
    Montana
    Yeah, these machines are pretty easy to diagnose, so not to worry. Just continue on with the trouble shooting. A dryer is not rocket science whatsoever.
    dented likes this.
  9. dented
    I-10 East onramp
    No motor noise or any sound at all when pushing the start switch after the initial click. I'll pull it apart and check belt first and then keep going. There are some thermal resistor type jobbies in there that are said to let loose. Now to find my multimeter....lol
  10. KG7IL
    KG7IL TDPRI Member
    Eatonville, WA edge of cowtown
    From what I have heard so far is Everything is fine during power up, but when actually push the start button you hear once click...
    Like Solenoid or Relay?
    I'm also going with the switch (safety switch for door closed)
    It's easy to test, manually actuate, bypass....
    Do the easy stuff first....
    dented likes this.
  11. RottenTheCat
    RottenTheCat Tele-Holic
    Drambuie, Africa
    Heads up - MANY PARTS - interchangeable between brands and priced from cheap to very expensive. For instance the motor on a dryer I just fixed was priced from any place around $75 to up over $300 depending on where you bought it. I actually found one on Amazon for $78 and bought it. Thermal fuses I get them by the dozen for like $6. They're about $5 each when you buy them one of the time! Same with lid switches. And same thing goes with thermostats they're all the same parts, and most aftermarket parts have the wiring spade connectors for any type of machine that they put it back into.... That is to say, both male and female of different sizes just use the connection you need. Timers are another story and so our timing boards but you can find those all over the place at different prices too
    IT PAYS TO SHOP AROUND
  12. alathIN
    alathIN Tele-Holic
    Indiana
    There are a couple-few of these online places that sell appliance parts and have a "troubleshooter" algorithm.
    https://www.appliancepartspros.com/repair-help/
    Often videos of how to do the job.
    Like I say there are a few of these type places so do some shopping around.
    dented likes this.
  13. dented
    I-10 East onramp
    Did everything it said in the manual and no codes appear on the panel. WTH? Tried it 5 times.
  14. dented
    I-10 East onramp
    Yep 69.95 for a house call.
    24 track likes this.
  15. dented
    I-10 East onramp
    Did that, no barrel roll.
  16. charlie chitlin
    Kimberton
    I hate those freakin' things.
    I search Craigslist for driers that have one big knob that goes "kkkkkkkkkkkkkkrrrrrrit" when you twist it and a button that says "START."
    I recently replaced one that had been in the house since 1979 with a similar one that will probably last at least 20 years.
    dented and Milspec like this.
  17. archetype
    archetype Fiend of Leo's
    Williamsville NY
    I've started shopping and reading reviews because I need to replace a Maytag washer and dryer from 1999. I put new timer assemblies in both of them about 11 months ago. The washer is now blowing its internal fuse and I've decided that they've exceeded their practical life.
    dented likes this.
  18. zimbo
    zimbo Friend of Leo's
    Rochester, NY
    Could be your vent is plugged up and it blew the fuse.
  19. KG7IL
    KG7IL TDPRI Member
    Ok.. but do you hear the electric motor turn. Listen for the MOTOR...
  20. dented
    I-10 East onramp
    no only the click when pushing start then it gives me three bells....click....push it again...ding ding ding, no motor hum, haven't taken it apart yet. working 12 days straight among other things.
