Dry/Dry/Wet?
aux8
Ireland
I'm wondering if there are any switcher pedals which could do this:
(A) DRY: Vox AC15 normal channel
or
(B) DRY: Vox AC15 top boost channel
and
(C) WET: Another amp
So, a wet/dry split which also lets me switch the dry signal between the two channels on the Vox amp
A + C
B + C
A + B + C (bonus)
(Edit: Oops, I had C as the Vox instead of the second amp.)
aux8
Ireland
I am at the beginning of thinking about it :)
If I split what I've got the way I think this goes it would be:
Wah, TU-3, Comp, BD-2, Rat, American Sound -> Vox amp
Chorus, Delay, Tremelo -> Fender SS amp (w. nice reverb)
Vox amp is new to me. I had been thinking to get an A/B to switch between Normal and Top Boost channels. Just to have that
Now I'm thinking, maybe I could combine that switch with a wet / dry split... Since I have the two amps there, so why not
aux8
Ireland
As an aside, I have been quite enjoying 'stacked tremolo' of TR-2 at relatively strong setting into milder tremolo on the AC15. Some a nice messed up sounds there
JohnnyThul
Germany
Lehle 1at3 Switcher can do that. It's programmable, or you can use it in standard mode and individually turn on/off the signals.
aux8
Ireland
I just found EHX Switchblade+ which looks promising. It is an ABY plus always-on tuner out
So I guess with that I could do something like
Code:
Dry effects -> TU-3 bypass -> switch input
  -> A -> Vox normal channel
  -> B -> Vox top boost channel
  -> Tuner out -> TU-3 output (mute)
      -> Wet effects -> Fender amp
So tuner would have display always on, and would act as a Wet amp mute when engaged
