Drummer Pluggin Help Please
Discussion in 'Recording In Progress' started by StuartJames, Jul 31, 2021.
  1. StuartJames
    StuartJames Tele-Meister
    Firstly, I’m inexperienced with drummer pluggins ( and home recording in general) I have no intention of diving to deep into it, just want something to lay down some practice loops and tracks and share the odd thing with friends.
    I have asked advise here before and since upgraded to Studio One 5 and have used the Steven Slate Free Drums. These loops do sound great and I really like the format of drag and drop and the way it’s set out, but none of the loops are for me. I can’t find a relaxed drum beat in there anywhere. It’s probably focused more towards hard rock.
    Any suggestions for another Drummer pluggin? I’m really just after simple drum loops that can be used for classic rock, rock, rock/blues and ballads. Ease of use is important
    Ideally something free would be great, but don’t mind paying for something that’s easy to use and sounds good
    I’ve seen Groove Monkee midi loops around and listened to some samples and they sound good. But I just can’t get my head around what they actually are? Are they simple drag and drop loops?
    Any help much appreciated
    tomasz likes this.
  2. tomasz
    tomasz Tele-Meister
    Europe
    I don't know what OS you are on, but I had my journey trying out different DAWs and drum plugins, but couldn't move away from OSX. Because of the drummer in Garage Bang/Logic. It guess, I just hate programming drums and with what I'm stuck on in OSX, I can get pretty much anything laid out quickly under 5 minutes, which allows me to focus on playing and songwriting.
    StuartJames and Mjea80 like this.
  3. Len058
    Len058 Tele-Meister
    Leeuwarden Netherlands
    I don't know about studio one but in reaper I can drag and drop midi files on an instrument track. So there's a way to use any midi file and let it go through the drum machine.
    Groove Monkey packs can be installed in SSD. I've got the 'Garage' pack and I followed the instructions to install them in SSD. They now show up in the grooves section of the plugin.
    StuartJames likes this.
  4. StuartJames
    Ah so I can use Groove Monkee loops through Steven Slate Drums? Then just drag on drop
  5. StuartJames
    I’m using Studio One with Windows
  6. naveed211
    naveed211 Friend of Leo's
    Iowa
    EZDrummer is great, I’ve used it for close to a decade now.
    My one complaint is that it doesn’t have a lot of hard rock/metal style loops in the main package (I don’t play much of that style anyway, just saying). So, if you’re looking for some straight up rock or blues/more conventional type loops, you’ll be very pleased.
  7. kafka
    kafka Friend of Leo's
    Closer than you'd expect
    If you're looking at just laying down some practice loops, then my suggestion is that drum programming is the wrong way to go. It's at least two more skills you'd have to pick up (programming and mixing), and is probably more expensive compared to the alternative.
    A company like Loop Loft https://www.thelooploft.com/collections/drum-loops has more loops of every variety than you could possibly use, all of them expertly played and mixed. It would be a lot cheaper, faster, and higher quality than anything you could put together on your own.
  8. Len058
    Len058 Tele-Meister
    Yup! I think you'll have to put the midi files in the appropriate folder of SSD an then it works.
  9. StuartJames
    So I managed to get some groove monkee midi loops going through SSD ( a reasonable task for a computer numpty like me). It’s super easy to use and sounds good. And I can add drummer packs as I go. Great solution. Thanks for the input everyone
    Daddydex and Len058 like this.
  10. runstendt
    runstendt Tele-Meister
    Bloomsburg PA
    EZDrummer is very accurately named. You can click out a beat and it will algorithmically identify which loops are closest to what you entered. At least for me personally it has the right amount of presets and variability. I've found Superior Drummer to have a bit too much variability. I pretty much use EZDrummer as a plugin in Reaper for all my drum parts, using a combination of the built in loops and midi files I create myself. Like @naveed211 said, the built in loops are limited to incredibly common patterns, but the expansion packs are reasonable. It works great as a standalone program too if you do not want to play around with a DAW.
  11. Daddydex
    Daddydex Friend of Leo's
    Pennsylvania
    I use Addictive Drums 2 and the experience was the same in regard to the Groove Monkey grooves. They are actually organized better than Addictive Drums own grooves. Glad it worked out for you.
    Dan
  12. InstituteOfNoise
    InstituteOfNoise Tele-Holic
    Los Angeles, CA
    I've been using the Groove Monkee stuff for well over 10 years. Used them for many TV/Film/Commercial work as well as for productions still these days. I use them with Slate as well, but I have most of their libraries. Probably use the Blackbird and the newer 5.5 deluxe kits the most. They are not quantized which is a good thing, so it can feel like a real drummer. They are actually played by drummers but triggered into MIDI. Once I'm happy with the arrangement, I stem out each individual track in their drum mixer to a track and at that point I treat it just like any other recorded kit. Thankfully the Slate libraries are not loaded with any processing like most others.
    They are having a big no coupon needed sale, so listen to the samples on each page and find what works for your style. Could easily be their basic groove/songwriter sets. It's not hard to modify any of the midi once you've dragged it into your DAW, if you want to make it adhere more to your tune.
  13. Rolling Estonian
    Rolling Estonian Friend of Leo's
    Bethesda, MD.
    Yeah but they have more metal expansion packs than you could wave a drumstick at! lol
    M
  14. memorex
    memorex Friend of Leo's
    Sweet Lorain, OH
  15. StuartJames
    That’s good to hear. I have already purchased the Ballads pack, will probably get a couple more. Fortunately there demos seem really good which makes it easy to pick
  16. InstituteOfNoise
    Los Angeles, CA
    And don't always let the pack name sway you... I've used stuff in a style that wasn't close to the style of the song I used it in. The only rule is there are no rules! Do what gets you close to the sound you hear in your head.
  17. nedorama
    nedorama Tele-Holic
    I used to play my own drum parts through a KAT DK-10, using first a Alesis D4 drum module and then Battery 4 soft synth.
    I then got into Drumcore by Sonoma Wireworks back when it was still called submersible music. Drum loops in Audio and MIDI recorded by famous drummers.
    It works, but after switching to a new computer I haven't reinstalled it yet as it still has teething problems with macOS Big Sur. I have Slate Drums and they work fine for songwriting.
    Almost all of these programs have free demo versions you can install to try, and it will come down to what you're comfortable with. I'd also look beyond MIDI and just look at audio loops - usually organized by bpm and you can find the tempo you're looking for and then just drag and drop.
  18. Canadian_Fender
    Canadian_Fender TDPRI Member
    I like GetGood Drums and EZDrummer 2. Often times you can get these on sale. And both have assortments of midi packs you can purchase. Lots of great info on them and demos on YouTube.
  19. Ed Driscoll
    Ed Driscoll Tele-Afflicted
    South of Dallas
    After years of using Acid drum loops, I switched over to Superior Drummer 3 in late 2017 after reading a review in Sound on Sound. In retrospect, I might have been fine with EZDrummer, which it's compatible with. Lots of great midi loops and great sounding kits.
