DRRI vibrato
Discussion in 'Amp Central Station' started by Neill Levine, Apr 16, 2014.
  1. Neill Levine
    Neill Levine Tele-Meister
    Sydney, Australia
    Hi all
    I tried to do a search, but I couldn't find this exactly.:confused:
    Love my DRRI and great sounding vibrato. The trouble is, when you aren't playing but have the vibrato engaged, it just pulses away, and it seems pretty loud when I'm playing at home solo. Is this the quirk of the circuit?
    I guess I'm hoping that others have encountered this.
    My question too to people who have the same problem (if it is a problem) - if you're working and have the amp mic-ed up, does that pulsing sound come through the PA much? Or is it covered by drums etc.
    Cheers
    Neill
  2. waparker4
    Philadelphia, PA
    It's.part of the noise floor of the amp and is completely masked by all the loud things on stage IME.
  3. Leep Dog
    Leep Dog Tele-Afflicted
    Yeah when you're playing louder or with a band you won't notice it. However, I recently had my DRRI serviced and I'm not sure what the guy did, but the ticking is now barely noticeable at any volume.
  4. waparker4
    Philadelphia, PA
    I think this pulsing is different from the common ticking problem.. basically the noise floor of the amp is at some low volume x and the vibrato is pulsing between 0 and x
  5. JayDee
    JayDee Tele-Meister
    Missouri
    I'm not sure if I understand the problem. Raising and lowering the signal is what it's supposed to do. There will be a "pulsing" in the noise floor when you're playing and when you're not playing. It'll be more or less noticeable depending on how you have the intensity set. Just click the footswitch off when you're not playing if it bothers you.
  6. Neill Levine
    Sydney, Australia
    Ah - I'll try to clarify if I can. If I have the vibrato engaged and play - beautiful. If I mute the strings or zero the guitar volume, the vibrato still 'pulses' or 'throbs' at the speed it is dialled to. When you play, you just don't hear it. If I can compare it to my 70's SF Princeton; in the same situation it is quiet. I do know that the circuit operates differently though. I don't know if I've made things clearer though!
    Cheers
    Neill
