Draining Caps: Resistor Question
Discussion in 'Shock Brother's DIY Amps' started by BradKM, Sep 23, 2012.
  1. BradKM
    BradKM Tele-Holic
    Charlotte, NC
    I'm preparing to tackle my first amp repair after watching a few online videos and reading a few tutorials.
    When draining the caps will a 10 watt - 100 ohm resistor work? The ones I've seen used in my source material were of lower wattage, but higher resistance (at least 480 ohms).
  2. hackworth1
    hackworth1 Friend of Leo's Vendor Member
    Volusia County, Florida
    The bigger the resistor, the longer it takes to drain the caps. You can drain the caps very quickly using no resistor. There might be a spark. The answer to your question is yes.
  3. BradKM
    BradKM Tele-Holic
    Charlotte, NC
    Thanks!
  4. rz350
    rz350 Friend of Leo's Ad Free Member
    Waubeka Wisconsin
    I would use the resistor, shorting certain electrolytics can damage them internally, plus it's hard on the terminals (and screwdriver)!!!
  5. Mat
    Mat Tele-Meister
    If you have a 12AX7 preamp then clip a simple jumper lead to earth and then on to pin 1 (not the other way around as you become earth if you touch the alligator clip unprotected).
    This will drain all the filter caps through the plate load resistor - leave it clipped on whilst working to ensure no drain back of current into the caps.
  6. tubeswell
    tubeswell Friend of Leo's
    NZ
    A simple way is to clip one end of your (insulated) gator clip DCVmeter lead to the chassis and the other end to the plate resistor of V1. The filter caps will then safely discharge through the amp's power supply rail in series with the meter, and you get to watch the voltage go down :)
    When you've discharged it, it a good idea to add a 220k 2W (bleeder) resistor permanently in parallel with the first (reservoir) filter cap, so that the caps always discharge when the amp is switched off. JM2CW
  7. Knight_Hawkish
    Knight_Hawkish TDPRI Member
    Millboro, VA
    Any ideas as to whether this might affect the character of the circuit/amp/tone? At that value (220k) you don't think there's any audible AC ripple being introduced to the amp via the power supply?
  8. printer2
    A drop in the bucket. Say you have one 6V6 in your amp running into a 5k transformer (impedance not resistance but the power supply does not know the difference) you could have 60mA running through the tube and 1.4mA through the resistor.
  9. KenH
    KenH Tele-Holic
    Pennsylvania
  10. printer2
    Which I agree with but that is assuming you have a properly working amplifier. If you do as I do and test parts of you build as you go along you could put power on the power supply to check it out and still have voltage there when you turn it off. Or if you are having a problem with your heater circuit and the tubes do not get hot but the SS rectifier charges up the capacitors. I rarely discharge capacitors but I always check to see if they are holding a charge. And if they are I discharge them.
  11. KenH
    KenH Tele-Holic
    Pennsylvania
    Makes sense. I never thought of it that way.
  12. DavidP
    DavidP Friend of Leo's
    Vancouver BC, Canada
    +1 on the 220K 2W bleeder...
    I do this on all my builds & rebuilds; its good insurance for that one time you mess up and think the caps are drained!!
  13. tubeswell
    NZ
    Doesn't affect the power supply at all. The filter caps are there to keep the power supply constant. The resistor just helps drain them quickly when the amp is off.
