Double Overdrives
Discussion in 'The Stomp Box' started by GuitarsBuicks, Jan 20, 2021.
  1. Askwhy
    Askwhy Tele-Meister
    Utah
    Big fan, as i like a tiny pedalboard and you use only one power input and often it is a smaller footprint than the same two pedals stacked with jacks. Especially the ones where you can determine the stacking order with a switch are extremely versatile and fun.
    Con- You have to find the perfect one, often you will like one side better than the other.
  2. willholt92
    willholt92 Tele-Meister
    Sheffield UK
    Always liked the Les Luis, but I ended up building a Tweed Princeton for that sound instead. Bit of an expensive alternative mind you haha
    El Tele Lobo likes this.
  3. Festofish
    Festofish Tele-Afflicted Silver Supporter
    Grand Rapids, MI
    On a whim I bought an Old Blood Noise Endeavor’s-Fault the other day used at my local GC. It sucked through the Fender but the Peavey 6505MH/Class112 roared! I still don’t think it’s for me. Overall I’d rather have single pedals to mix and match but that’s just me.
  4. GuitarsBuicks
    GuitarsBuicks Tele-Holic
    Somewhere between here and there
    I tend to be in the middle between having separate overdrives to get the sound I want (EHX Hot Tubes(Overdrive set to 1:30 or so) between the two sides of a Route 66 into as SRRI), and what is practical to take on a gig. I don't use an actual pedal board, I usually just put them on the ground somewhere between my amp and where I am standing and hope my cord doesn't drag them too far out of line. For a long time all I had was the Hot Tubes and I couldn't get everything I needed from it. As a Matter of fact it I have almost completely retired it from my gigging board because it has a tendency to be extra hissy and annoying.
  5. northernguitar
    northernguitar Friend of Leo's
    North of Toronto
    Treble booster into muff fuzz=gritty distortion with girth!
    loopfinding likes this.
  6. loopfinding
    loopfinding Friend of Leo's
    europe endless
    for sure. the tendency to copy amp style tone knobs to cut treble is wrong and we’ve been doing it wrong for 50 years. They’re absolutely useless on most gain pedals (I thought I was trying to add upper harmonics??). but a pre-gain bass cut, that’s the secret to unlocking any gain pedal.
    northernguitar likes this.
  7. GuitarsBuicks
    V3 Route 66 has both a bass and treble knob as well as a clean mix knob on both sides. Makes it a nice set and forget...until you go from a vintage tele to a Humbucker and you forgot to turn the volume down. Then the front row all has to go buy wigs and fake eyebrows.
    Festofish likes this.
  8. JuneauMike
    Alaska
    The idea of a double overdrive or a double delay makes a lot of sense and should be awesome. I'm old fashioned and I think I just like to stack overdrives separately. It's nice to drop in something new every now and then and enjoy the difference.
  9. jackal
    jackal Friend of Leo's Platinum Supporter
    mojave desert
    Rat Deucetone anyone?
  10. johnniegoat
    johnniegoat Tele-Meister
    United Kingdom
    yes
    I currently own these
    Snouse Blackbox Duo - new to me, still figuring it out. appears it wil be excellent
    VS Audio Royal Flush - awesome
    TRex Moller - very, very good
    i have also owned
    VS Jekyll & Hyde - liked both sides - would have preferred the TS in front of the Shredmaster
    Fredrick King of Klon - really very good; sold to fund something else
    they are typically smaller than 2 pedals, esp as you don't have to put a patch cable in the middle; they only take up 1 spot on the power supply
  11. northernguitar
    North of Toronto
    The right bass-cut is the key to some heavenly crunch and notes that really cut through the mix. My Yamaha Revstar has a bass-cut switch that came stock. I’ve replaced the pups with a 498/490 set. The bass cut combined with the 498 is excellent for any crunch tone I want.
  12. Bob Arbogast
    Bob Arbogast Tele-Afflicted Silver Supporter
    Lowell, Michigan USA
    At the moment my pedalboard is Tuner-->Z-Drive-->Delay. Good sounds from the Z-Drive, no doubt. And, yes, the 3-band eq lets you shape the voice just the way you want.
    bigben55 likes this.
  13. bigben55
    bigben55 Friend of Leo's
    Cincinnati, OH
    Another newer, unique dual OD that i wanna try is the Wilson Effects Angry Goat. Its a Dumble type(his Lotus drive) one one side, and his Klon clioe on the other, with the Klone stacking into the Lotus. Basically a Zendrive and a Klon. Wilson Effects are awesome, ive had 5, still have 2, a wah and a univibe. I just got away from fuzz, but he does killer fuzzes if thats your thing.
    snottyboy likes this.
  14. Grateful Ape
    Grateful Ape Tele-Afflicted
    Mosky XP into a Timmy...
    What is the amp/guitar you're using?
  15. Hoodster
    Hoodster Friend of Leo's
    Oregon
    Another really good one is the Xotic AC Plus, especially both sides stacked.
  16. dburns
    dburns Friend of Leo's
    Darby, Pennsylvania
    Not easy to find but I like the Barber Direct Drive Dual Channel (DD/DC).
    1/2 Gainer is really good too, works the same way, but the DD/DC offers more gain.
    Chiogtr4x likes this.
  17. Peegoo
    Peegoo Poster Extraordinaire
    Between the Raindrops
    I have a Wampler Dual Fusion that does everything I need stacked overdrives to do.
    Years ago I had a Way Huge Camel Toe that sounded really great, until a pal made me an offer I couldn't refuse, and sold it. Those originals are commanding stupid money these days. I think Dunlop owns Way Huge now and they have a few modern versions out.
  18. Jellyroll
    Jellyroll Tele-Holic
    Detroit, MI
    This has blown my mind, though honestly it doesn't really count as dual overdrive since the two sides run in parallel rather than in series. It sounds bonkers good though, and you can mix clean signal back into the output stage!
  19. gridlock
    gridlock Poster Extraordinaire
    Tampa, Fl
    For Fender amp overdrive, I often run my elMo or TS808HW overdrives into my Wampler Black 65 OD pedal.
    The Black ‘65 adds bass, openness, and smooths the tone of the two TS type pedals. SRV tone at most any volume.
  20. Charlie Bernstein
    Augusta, Maine
    I had a King of Tone for a while, but the two sides were too similar. You can fool around with the switches inside, but still.
    Now I have three separate overdrives in a row, and they all have different jobs: boost, presence (on all the time), and hair.
    I have much better luck than I had with the King of Tone, even though it was a truly magnificent pedal. Silver lining: I made over $100 when I sold it, hee-hee
