Don't bust my bushings too hard...
Discussion in 'Tele-Technical' started by McGlamRock, Sep 27, 2020.
  1. McGlamRock
    McGlamRock Poster Extraordinaire
    San Francisco, CA
    Long story short, the tuners on my partscaster bit the big one. I bought a replacement set that were supposed to fit in the existing bushings but unfortunately they did not. I could go back and exchange the tuners for a set that would fit, but I thought this might be a fun learning opportunity.
    I put in the new bushings, but the holes in the headstock were a just little too big. So I wrapped little pieces of cardboard around the new bushings and started fitting them in. I'm starting to think this might work...
    3-Chord-Genius and rangercaster like this.
  2. Deeve
    Deeve Poster Extraordinaire Silver Supporter
    Ballard
    I admire the creativity. :cool:
    I used small pieces of shrink wrap to fit over the slot-head tuner shafts that were missing bushings on a dumpster-find guitar.
    Improvise, adapt, overcome.
    Peace - Deeve
  3. gsh1968
    gsh1968 Tele-Holic
    London UK
    Cut strips from an aluminium can to wrap around the bushing body to use as sleeves. It'll give a better mechanical fit without the compression you will experience over time with the cardboard.
  4. Fretting out
    Land of Mary
    I’ve heard good results from the method posted above
    I’ve used painters tape when this happens
    mkdaws32 likes this.
  5. megalo82
    megalo82 TDPRI Member
    italy
    I’ve had the same problem with my Squier bullet, so at the Home Depot I bought a rod of aluminium and I’ve made the adaptors with the late. I’ve tried wrapping with everything that came to my mind but it was always a bad work, not perfectly centered and not very steady
    64C63C99-D04A-4165-94A2-84D626EA160E.jpeg 8473C868-597D-4D22-92FB-DF26394D072F.jpeg 4AF9BF51-F637-4781-8345-98496091A3E6.jpeg
  6. hemingway
    London, UK
    I tried the aluminium foil method and didn't like it.
    So I followed another poster's advice and gradually built up the holes with superglue. When it was dry I filed away any excess, and it worked perfectly. Eight years later, no issues.
  7. beagle
    beagle Friend of Leo's
    Yorkshire
    I first did this in the 1970s. Now, I can afford to just buy the correct size bushes.
    Fretting out likes this.
  8. charlie chitlin
    Kimberton
    I'm not sure how much space you have to take up, but there's a size of copper tubing that has the perfect o.d. and i.d. for putting stock tuners back where schallers used to be.
    Consider finding tubing with the proper i.d. and reaming the holes to accept it.
  9. Matthias
    Matthias Friend of Leo's Gold Supporter
    I've tried a few things over the years. If they're just slightly off, normal sticky tape sticks well and doesn't wrinkle too much as you push the bushing in, and you can easily cut it to size before applying it so it's invisible.
    If they're 8.5mm bushings going into 10mm holes, You can get nickel conversion bushings off eBay for about $5.
    McGlamRock likes this.
  10. Wallaby
    Wallaby Tele-Afflicted Silver Supporter
    Midwest
    I've fixed stripped or over-large pickup bobbin screw holes this way. I learned it's important to try to keep the layer-by-layer build-up symmetrical, by the way.
    hemingway likes this.
  11. Gardo
    Gardo Tele-Afflicted
    Lancaster Pa
    bushings are available for about $10 if you are determined to keep the tuners
  12. McGlamRock
    San Francisco, CA
    The bushings seem to be holding ok. Before I screwed the neck back to the body, I gave the headstock a good whack against the couch a few times to make sure the bushings were securely in place. Seems like they're in there pretty good.
    And even though the cardboard is sticking out a bit, I think i can live with it.
    The best part is, if any of the bushings come loose at a gig, I can just ask the bartender for an empty six pack (or just a can)
  13. edchavez
    edchavez Tele-Holic
    Arkansas
    Spent 9mm brass works too...
    Kevin Wolfe likes this.
