Does your favorite drive pedal have a sweet spot below full volumeo on the guitar?
Discussion in 'The Stomp Box' started by 4pickupguy, Dec 11, 2019.
  1. 4pickupguy
    4pickupguy Doctor of Teleocity
    Fort Worth, Texas
    Something I noticed on my Rat and then my first two fuzzes. I set the Rat for a little higher volume, roll back the guitar volume knob just a bit and it gets much more harmonically complex and much more responsive. A magical sweet spot that just sings. The fuzzes (Fulltone ‘69 and Moollon Octavia) do as well but nothing like the Rat. None of my other drives do this. What is going on to cause this? Any other pedals do this?
    capt pearl and Seasicksailor like this.
  2. sirbergersworth
    sirbergersworth Tele-Holic
    St. Louis, MO
    This is true for lots of pedals and in my experience it works even better for amps. I always think my tone is better with the amp cranked more than I need and use the guitars vol knob to dial it back a bit.
    Seasicksailor likes this.
  3. Frodebro
    Seattle
    I generally keep my drive pedals set just a hair above unity gain, with the exception being the trusty old "Tube Screamer with the gain on zero and the volume slammed".
  4. naveed211
    naveed211 Tele-Afflicted
    wisconsin
    I find that with fuzzes a lot, especially germanium. Balls to the walls on full volume, but a full spectrum of sounds all over the guitar volume sweep.
    4pickupguy likes this.
  5. Gyprock
    Gyprock TDPRI Member
    Jersey
    Less of a hot signal perhaps? I can't use my Mooer Gray Faze as it absolutely splutters beyond any audibility (even at zero) unless I roll my volume back to at least half. This is on broadcaster/twisted tele pickups. Sounds absolutely fine on a junk strat copy however...
  6. Fiesta Red
    Fiesta Red Poster Extraordinaire
    Yes...my favorite Overdrives—TS9 Tube Screamer and Danelectro DO-1 Daddy-O—have specific sweet spots that have some sort of singing harmonic convergence...
    I’ve noticed that the “room” in which I’m playing will affect this as well, which means that the settings will sometimes have to be adjusted to reach the same sound/effect.
  7. beninma
    beninma Friend of Leo's
    Earth
    Yah I'd say so. Maybe more critical with amps though as was previously mentioned.
    I really need to start disciplining myself to set up with the guitar volume at 75-85% and turn up for a boost. It makes everything come out better. If setting up with 100% volume it gets really really easy for any pedal to be too bright when you kick it on. And you lose a lot of your ability to roll off the volume unless the overall amp volume level is very loud. On top of all that the best rhythm sounds with a standard wired Tele don't seem to be with the volume at 10 on the guitar.
    Of my pedals I'd say the Op Amp BMP I have is the one I am most likely to roll the guitar volume back when I'm using it.
  8. ReverendRevolver
    ReverendRevolver Tele-Afflicted
    Ohio (Nerk)
    Part of the reason I so desperately want to mod my big muff is my favorite sounds only seem to happen with my 75, and while I can accept that, I want additional options so I can find some equally favorite sounds with other amps.
    Specifically, I cant seem to get my "wrestling a dinosaur " fuzz happening without my toronado (and its gibson 57s) along with the 75. I have been able to get "barely sane with peach skin edges" with my supro, but my mustang sounds too weak compared to even the single coils on the DS or Tele.
    So, yes? Sweet spot(s) that migrate.
    Oh, my Soul Food does this awesome thing far below unity: I dial in just a bit dirty on the far right knob, put middle knob at 12oclock, then drop below unity gain on volumeknob. Then I engage the fet gain stage on my Supro and have sweet crunch.
    Whenever I buy a Rat finally I'll let you know what i find with both relevant amps. I suspect similar hidden sounds?
  9. Seasicksailor
    Seasicksailor Friend of Leo's
    Keynsham UK
    It's definitely so for my Broadcast clone (at least at the second stage of gain), and for my Dark Side.
    The Broadcast becomes less 'harsh' but retains sustain, while the Dark Side just becomes less fuzzy and more overdrive-y. :)
  10. Seasicksailor
    Keynsham UK
    But reduce the volume too much and you lose all the 'magic'.
  11. schmee
    schmee Doctor of Teleocity
    I have never had an OD over maybe 1/3 volume.
  12. PastorJay
    PastorJay Tele-Afflicted
    California
    Right now I've got four ODs I use, a TS style, a Rat style, a Klon clone, and a (new) Boss SD-1. I find with each of them, and no matter which guitar I'm playing, that I can a variety of useful tones with guitar volumes at different points, sometimes as low as about half way up, and certainly about 3/4 or 8 out of 10.
  13. Seasicksailor
    Keynsham UK
    Just to be clear, the OP is talking about the guitar volume, not the pedal volume (right?). Unless I'm mistaken, some posts seem to be talking about the pedal volume.
  14. Lies&Distortion
    Lies&Distortion Tele-Afflicted
    SE Michigan
    I would assume yes. And yes.
  15. 4pickupguy
    Fort Worth, Texas
    Yes. Edited the title to say it also. Rolling the guitar volume back and finding a sweet spot where things just “open up”. There is a spot where there are way more harmonic overtones and it feels more responsive to soft/hard inputs. It happens on any pickup selection or even any guitar. It’s not a subtle thing at all either. I swear I’m not sawing BBs here. I’m not where I can record a video demonstrating what I’m talking about but I have recorded some things set this way. It would really need to be a live video. Also, thinking about it, I wonder if it would manifest itself in the freq analyzer of my DAW..? I need to try that. As stated before my Rat does this most notably but I have a FF and Octavia style pedals that do the same thing. There is an old demo video by Allen Hinds using a Bob Burt AH-1 Distortion pedal where he alludes to it twice. Once when he is talking about 'notes and overtones' and again when he sets up his "lead setting" by rolling the volume back a little (8 or 9)... anywho, thats the closest video I know without making one myself focusing just on that quirk..
  16. Lies&Distortion
    SE Michigan
    I have read enough from others to believe it, but it is pretty subtle for me. One of those things that just doesn't make a huge difference to me.I will have to try it when I get home.
