Does putty affect the tone of a solid body guitar?
Discussion in 'Finely Finished' started by MainGuitarMan, Jul 26, 2019.
  1. Yes
    2 vote(s)
    6.3%
  2. No
    12 vote(s)
    37.5%
  3. You need to get a life kid..
    18 vote(s)
    56.3%
  1. MainGuitarMan
    MainGuitarMan NEW MEMBER!
    Philippines
    This might be a noob question, but I'll ask anyway. As the title says, does putty affect the tone of a solid body electric guitar?
  2. joealso
    joealso Tele-Holic
    East Haddam, CT
    Can I vote twice?
    DrPepper, howardlo, drf64 and 3 others like this.
  3. strat a various
    Depends where you put it, I'd suspect.
  4. Teleterr
    Teleterr Friend of Leo's
    Lewes De.
    You mean mounting a contact Mic or replacing half the body wood ?
  5. jimbo735
    jimbo735 Tele-Afflicted
    Michigan
    NOT IF YOU CRANK THE AMP.:)
    Fretting out likes this.
  6. Fretting out
    Fretting out Tele-Holic
    Land of Mary
    I suspect that it probably won’t affect the tone of a solid body but sometimes other variables may be affected while repairing an instrument that may change tone
  7. Dismalhead
    Sacramento, California
    I like to put a bit of Silly Putty in each of my guitars. Not to affect the tone, but I can take it out and play with it when I'm bored.
  8. Chunkocaster
    In space with Ziggy
    I think if you packed a bunch of it under the bridge or covered the pickup with it the tone would be affected some.
    Dismalhead likes this.
  9. 24 track
    24 track Doctor of Teleocity
    kamloops bc
    the only way putty will affect the tone is if you pick with it, or you roll it up to make guitar strings with it., or you smear it on the pickups .
    jimbo735 and vgallagher like this.
  10. Mike Simpson
    Gilbert, AZ (PHX)
    I don't know... I have never used putty on a guitar. Pretty much all wood putty is crap and is going to shrink and expand differently than the surrounding wood. Eventually all putty will telegraph through the finish to show where it is if it doesn't crack. Cut out a piece of similar wood to fill the area. Fix it right.
  11. schmee
    schmee Poster Extraordinaire
    A little "putty" (what ever that is!) Shouldn't do anything. The louder you play, the less whatever the body is made of matters. But at low volumes body type and material matter more.
    I've repaired a few guitars with Epoxy resin, including hollow body and acoustics, and I heard no change.
  12. jvin248
    jvin248 Poster Extraordinaire
    Lions & Tigers oh Mi !
    Make a guitar all out of putty and see...
    Generally your tone is driven by the pickups and the pots and caps. Most comparisons people forget about pots have a 20% factory tolerance range so it's an important issue rarely protected against. Caps have a 10% range. Pickups have an unknown but suspiciously wide tolerance because there is no reported tolerance spec on any I have ever seen.
  13. BelairPlayer
    BelairPlayer Tele-Afflicted
    Ca
    Not as much as an ongoing, effective practice routine.
    Peltogyne likes this.
  14. Blrfl
    Blrfl Tele-Holic
    Northern Virginia
    Tone putty will improve it.
    howardlo likes this.
  15. jrblue
    jrblue Tele-Afflicted
    Santa Barbara
    Builders say that materials are major contributors to tone, and while this is true, the real question is "how much?" and that depends on lots of other things. For high-gain playing at reasonable volume, some factors make less and less of a difference relative to the impact they might have for really clean tones at low volume. For ex., you can seek sustain through the guitar's mechanical and acoustic qualities, or seek sustain largely through other components of your rig. In the first case, wood choice -- and the absence of vibration-absorbing putty! -- would be significant; in the second, less so, by far.
  16. drf64
    drf64 Poster Extraordinaire
    Ada, MI
    If you put it on your fingers it will.
  17. magicfingers99
    magicfingers99 Friend of Leo's
    atlanta
    if you use silly putty, you can get better harmonics by using silly strings.
    Teleterr likes this.
  18. Dacious
    Dacious Poster Extraordinaire
    Godzone
    I'm just repainting my Melody Maker - following the regime of coatings suggested, it's going to end up with a couple of pounds of paint on it. And that's with just half a dozen coats of nitro. A few ounces of putty - inconsequential.
  19. RadioFM74
    RadioFM74 Friend of Leo's
    Italy and Switzerland
    Where do you intend to put it, and what for? Without this info, difficult to answer although for 90% of all imaginable quantities and places of application the answer would be “no”.
  20. Peltogyne
    Peltogyne Tele-Afflicted
    Northern California
    Yes, knowing there is putty can change the tone you hear in your head.
    No, it will have no effect on the vibrations in the air outside of your head.
