Does anyone sell B-Bender bodies?
Discussion in 'B-Bender Forum' started by GaryOsborne, Oct 30, 2014.
  1. GaryOsborne
    GaryOsborne RIP
    Nashville, TN
    I'm buying this Nash Tele and it comes w/ an extra Nash neck (for free!). I've always wanted a B-Bender Tele but haven't ever really loved the Fender B-Bender guitars. I was wondering if there's any companies that sell bodies with P/W style B-Benders in them. I've found a couple American Fender B-Bender bodies on eBay for like $700. It be great if MJT did bodies w/benders. Is there anywhere I should be looking?
    The cheapest one I've seen is the one I mentioned from eBay. It's a black USA fender Nashville b-bender body. It's routed for 3 pickups and for $700 you get the finished body, bender installed, bridge and neck plate.
    Man I likely to find a better deal? I know these P/W style benders get expensive.
  2. telex76
    telex76 Doctor of Teleocity Ad Free Member
    Fort Worth,Tx.
    Nashville B-bender isn't a P/W bender. It's a P/G bender and that's different and to me at least it's nowhere near as good. You can find them though, and you can't find the P/W bodies.
    Why not contact Forrest Lee Jr.
    There are a couple of good B-bender guys on the forum, can't remember their names right off.
    Post on the B-bender Forum and ask if someone will do one for you.
    http://www.tdpri.com/forum/b-bender-forum/
  3. blackguts
    blackguts Tele-Meister
    Saskatoon
    I ordered a PG from Hipshot and took a router to a used American Standard. It was easy and fun.
  4. GaryOsborne
    GaryOsborne RIP
    Nashville, TN
    Thanks for the info. I thought they were the same. What's the difference between the PW and the PG?
  5. GaryOsborne
    GaryOsborne RIP
    Nashville, TN
    I was trying to find the B-Bender part of the site to post this in but I failed lol.
  6. GaryOsborne
    GaryOsborne RIP
    Nashville, TN
    Ok so I found a pretty good thread about it on another forum. So I understand how the P/G is much easier to install and thus cheaper.
    My question is, how much better is the P/w than the P/G? Is it worth that much extra money? What are the drawbacks to the P/G? I know a few guys here in Nashville that have the Fender Nashville B-Bender Tele and they love it and never complain about the bender.
    Also, if you got a guitar with a P/G in it, could you eventually upgrade it to a P/W? Or is the routing different?
  7. telex76
    Fort Worth,Tx.
    P/G and P/W are too different to ever swap from one to the other.
    P/W has the body route with the bender in the body. P/G was developed to make it possible to put it together on an assembly line. Less body routing and most of the unit sits outside the guitar body on a plate.
    P/G works fine, some people have a few issues that they have to solve with them.
    My main dislike for the Nashville B-Bender is that all of them I've ever tried were monstrously heavy.
  8. GaryOsborne
    GaryOsborne RIP
    Nashville, TN
    What about Joe Glaser? He's here in Nashville and I think he does benders
  9. FallsRockShop
    FallsRockShop Tele-Holic Vendor Member
    Cuyahoga Falls, Ohio
  10. Brandon mac
    Brandon mac Tele-Holic
    north alabama
    If it were me I would contact forrest lee jr.
  11. Chet Johnson
    Chet Johnson Tele-Afflicted
    Woodsfield, OH
    Wd sells pre routed bender bodies for parsons white as well as the bender parts. If youre after a parsons bender I recommend Bill Bores. $585 in any tele I believe
  12. telex76
    Fort Worth,Tx.
    He does the Glaser bender which is a completely different mechanism.
  13. Chet Johnson
    Woodsfield, OH
    If you want the finest saddle bender I would contact charlie mcvay www.mcvaybenders.com I have a mcvay b bender in my main tele and one in my esquire. Both are flawless, work smooth and silent, and stay in tune fantastically. Ive never had to even adjust the tuning stops after string changes.
    If your budget doesnt permit a mcvay, I would recommend andy Kirkpatrick or bill bores for designs identical to glaser for about half the money.
  14. GaryOsborne
    GaryOsborne RIP
    Nashville, TN
    What is the price range of the mcvay?
    What about the others?
    It seems like the most economical option is to buy a Fender B-Bender Tele body for like $600. I'm sure I'd be fine with the P/G style that's in them. It's wild how expensive these things get!
  15. GaryOsborne
    GaryOsborne RIP
    Nashville, TN
    Wow. After looking at the prices (I knew they'd be high) but geeeeeez. It looks like Joe (who's here in Nashville) will put his B-Bender in a Tele for $545. He'll do a Parsons bender for $595 and the Parsons/White "Long Throw) is $645. What does long throw mean?
  16. Chet Johnson
    Woodsfield, OH
    The mcvay benders are $850. Bill bores does a parsons or glaser style for $585, andy Kirkpatrick is in the neighborhood of $500.
    If its your first bender, a fender body with bender is a reasonable choice. I bought one new in 1997 . With some modifications I played that as my main gigging guitar for 13 years untilI started building my own guitars and had a mcvay bender put in one for myself.
    As for the fender bender and body alone:
    Theyre all pretty heavy. Around 2001 they changed to poplar from alder . You might luck out and find a lighter one but dont get your hopes up.
    Also , there is no tension adjustment on the spring. I found it too loose and caused many accidental actuating of the bender by moving around any. This is easily resolved by cutting off loops of the spring and bending over a new loop . Shortening the spring three loops gave me the desired "stiff enough to not be accidental, but not difficult to use".
    Hope this helps.
  17. Chet Johnson
    Woodsfield, OH
    Long throw basically means you have to press the neck further to reach a whole step. Some guys like it for slow drawn out bends. To do those slow bends on my standard throw benders I just push slower.
  18. GaryOsborne
    GaryOsborne RIP
    Nashville, TN
    Ok. Is there one where you can press the neck all the way out for a full step but only push it half way for a half step? Or is that basically what your describing?
  19. GaryOsborne
    GaryOsborne RIP
    Nashville, TN
    Thanks. That was really helpful. If I got a Fender one is have Joe of someone here set it up right.
    When you say heavy, how heavy are you talking? For example, how heavy is a typical Fender B-Bender Tele (not just the body, the whole guitar)?
  20. Chet Johnson
    Woodsfield, OH
    I think mine was about 9 lb as a complete guitar.
    There is no in between stop for a half step. Just a single adjustment for the tu ing point of the pitch it bends to. You could stop pressing halfway but youd have to listen and do that by ear.
