Does anyone?( Compressor content)
Discussion in 'The Stomp Box' started by jackal, Jul 17, 2018.
  1. jackal
    jackal Friend of Leo's Gold Supporter
    mojave desert
    Does anyone here use their compressor for rhythm playing only? I love the string to string balance I get when playing leads, but chording the wound strings just seem to disappear in the mix. Wondering if a good compressor would help this out?
  2. jrblue
    jrblue Tele-Afflicted
    Santa Barbara
    I do -- lots. I don't like the way some guitars have a really explosive attack that then falls off remarkably in level, even if the note itself is sustained audibly. For me, the compressor is less a tool to generate sustain and more a means of reducing the level difference between immediate attack and the same tone nanoseconds later. So I find modest compression really helpful for rhythm. I use other means to arrive at favorable string-to-string balance -- beginning with pickup adjustment.
  3. stratoman1
    stratoman1 Friend of Leo's
    Virginia Beach, Va
    I use compressors a lot at low volume no matter what I'm playing
    twotone60 likes this.
  4. 4pickupguy
    4pickupguy Doctor of Teleocity Silver Supporter
    Fort Worth, Texas
    Depends. Funky middle position stuff sounds cool with compression. But, I mainly use it as a “clean overdrive” for clean leads or to bring out clean harp or swept harmonics.
  5. Kayle McGuire
    Kayle McGuire Tele-Meister
    I’m the opposite. I use it for lead only! I like more dynamics in my rythym playing, but smoother leads.
    Modman68 likes this.
  6. tele_pathic
    tele_pathic Friend of Leo's
    St. George, UT
    My Xotic SP compressor is my only “always on” pedal. It’s fantastic! The blend knob, while doesn’t really set it apart,makes a HUGE difference.
  7. LOSTVENTURE
    LOSTVENTURE Tele-Afflicted
    Charlotte, NC
    Where do you guys place the compressor in your signal chain?
    No effects loop available here (older Vibrolux).
  8. 4pickupguy
    Fort Worth, Texas
    After drives and preamp, in front of Verb, Delay and Trem.
  9. tele_pathic
    St. George, UT
    My is second after my tuner, so first in line
  10. DaveKS
    DaveKS Friend of Leo's
    KS
    Well the lower the freq of string the more amplitude and power they have. So compression circuits will trigger easier on the plain strings and will do upward compression. The more powerful bass strings will more likely involve some amplitude limiting by comp because they exceed the threshold more. So yes lower registers on your guitar can become clearer, they're having their peak amplitude limited by the compression circuit.
    That's why lot of studio mix use multi-band compression that apply different compression ratios from high to low
    soundchaser59 likes this.
  11. luckett
    luckett Banned
    Upward compression? That's an interesting concept.
  12. Asmith
    Asmith Friend of Leo's
    East Yorkshire, England
    I use them for a bit of everything sometimes I need a more level sustain on a clean chord. My issue with compression is that I like to hear the attack of the note and I was using a stock CS3 and really wasn't enjoying it because no matter the setting it seemed to kill the attack note or at least make it sound unnatural.
    I modded it and put a blend in place of the tone control and now set the compression side so it flattens the attack and the blend control puts the attack back in.
    Maybe in your situation you should stick and eq after your compressor and you might be able to get a similar effect that a multi band comp would produce.
  13. twotone60
    twotone60 Tele-Meister
    Charlottesville, va
    This would be my exact response here as well.
  14. Pepi
    Pepi Tele-Afflicted
    Indiana
    Mine is on all the time. UNLESS I start adding distortion to my sound
  15. EddieLocrian
    EddieLocrian Tele-Afflicted
    Isle-of-Wight
    If you turn the compression amount down and the volume up can you use it as a clean boost?
    and is it any good?
    Eddie.
  16. tele_pathic
    St. George, UT
    Yes, an Xotic SP compressor could be used in this way. If I had a second one, I might use it this way.
  17. Thin white duke
    Thin white duke Tele-Afflicted
    italy
    I use mine always on, first in chain, Mooer yellow comp, very nice one....
  18. NWinther
    NWinther Tele-Afflicted
    Denmark Solbjerg.
    First in chain, and mostly only for rhythm and some swell stuff, very few times for clean leads.
    It has a blend....which I wish I could turn into a tone control instead...blend with a seriel effect is useless to me, don't get it one bit....but I like the sound of the comp itself and just do not use that blend thingy...ever( have tried several settings and all that, back when I worked as pedal maker we even installed one on a prototype comp, but removed it again, just did not see the need, guess there are different needs :D )
    I use it now and then with drive as well, never just leave it on, it is an effect for guitar, not a permanent thing....
  19. soundchaser59
    soundchaser59 Tele-Afflicted
    Up The Creek
    Same here, always on. I don't squash it, so I always retain some dynamics. But I have a heavy hand, so it helps me avoid a lot of fizz that can happen when I strum too aggressively. If I were playing cranked up then I would not use it for leads/solos.
  20. 4pickupguy
    Fort Worth, Texas
    Yeah, strange, but its real. Compander without the “comp”... Familiar mostly as a sidechaining practice...
