Does a Twin Reverb get louder past 4?
Discussion in 'Amp Tech Center' started by jwp2, Jul 2, 2019.
  1. WildcatTele
    WildcatTele Tele-Meister
    McPherson, KS
    Had my '65 reissue for seven years and only one time did I ever have it past 2, even for outdoor gigs. Just wanted to see if the claims of "smooth creamy distortion when turned up" were true. The only thing that got distorted was my sense of time and space.
  2. jimbo735
    jimbo735 Tele-Afflicted
    Michigan
    And they stay really heavy too after 4.
    Especially with two EVM speakers in it.:)
  3. tubelectron
    tubelectron Tele-Holic
    France
    Sure ! The weight of two anvils... :eek:
    A+!
  4. Matt G
    Matt G Tele-Afflicted
    I have a 2013 TRRI, although for the present I can't play it at serious volume. My usual 'house' setting was 3, which was loud enough but not offensive. Absolutely no risk of hearing damage at that level. Just right for a back porch player in the suburbs. Putting it on 6 was too loud, and 8 was way too loud. I'm not sure if I've ever had it on ten. And yet . . . I've never got the sense that it was as loud as people make out. I do sometimes wonder if the thing is defective. To answer your question, though, there's a distinct taper in mine. My gut feel is that it gets to about 2/3 total volume at 5 or 6.
    jwp2 likes this.
  5. strat a various
    Usually. They are typically loudest between 9 and 1. That's when the loud gigs happen. Sometimes they get very loud around 4 if they are at an outdoor festival or county fair.
    Enough of that ... if a Twin Reverb doesn't get a lot louder between 4 and 8 or 9 on the Volume knob, it needs to see a tech.
    BobbyZ and jwp2 like this.
  6. Beachbum
    Beachbum Friend of Leo's
    Sand Land
    Past four on a Twin your only concern should be whether you want to break your own windows or you neighbors windows as well.
    jwp2 and Modman68 like this.
  7. Silverface
    Lawndale CA
    However, depending on how they are biased the amp may max out on headroom at ANY arbitrary volume control setting. In that case the amp may get dirtier - or louder - or both - as you turn up the control. EVERY time you replace power tubes you ned to check the plate voltage & bias, and tweak the bias setting a bit by ear until you find the sweet spot for YOUR style of playing.
    BobbyZ likes this.
  8. jwp2
    jwp2 Tele-Holic
    Chicago Ill
    I hate to admit it but I didn’t bias the amp after the power tube replacement. I do love the sound I get from it though and I may not be exactly on the sweet spot but it’s really close.
    I need to get it into the shop soon though for a check up.
    Paul in Colorado likes this.
  9. swampyankee
    swampyankee Tele-Holic
    Southeastern MA
    I have trouble hearing myself in the mix, or at least hearing my tone. I now use tiltback legs on all my larger amps and it solved my problem, including my SF Twin. Now i have to be careful not to blast myself out as well as my audience. The 8 to 10 foot rule might help.
    Sent from my SM-G970U using Tapatalk
    jwp2 likes this.
  10. brookdalebill
    Austin, Tx
    The late 70s “ultralinear” models really get louder after 4.
    Some guys disrespect em’, but for headroom, punch and clarity, they’re hard to beat.
    They’re also hard to lift.
    I toured in a bar band with one.
    It never let me down!
    BobbyZ likes this.
  11. strat a various
    Check it in a dark room. If it's not red-plating at full volume, you are probably OK. If it sounds good, it's not biased too cold. Back in the day, that's what we did, put in the tubes, cross our fingers. Better tubes maybe back then.
    jwp2 and BobbyZ like this.
  12. jwp2
    jwp2 Tele-Holic
    Chicago Ill
    I’ll check it out in a dark room forneed plating at full volume.
    Thanks for the tip Strat a various. (Very cool name)!
    It sounds really good so I don’t think it biased too cold. I sort did what guys used to do back in the day.
    I replaced the tubes and crossed my fingers!
    BobbyZ likes this.
