Does 3 string neck need truss?
Discussion in 'Tele Home Depot' started by eddie27, Jul 5, 2016.
  1. eddie27
    eddie27 Tele-Meister
    Nashville
    I'm building a 3 string guitar for my son using a 23" scale neck i bought from a cigar box guitar store. Since there won't be much tension (it will be strung with light gauge G, B, E) I'm thinking lack of a truss won't be an issue. Does that sound right?
  2. metecem
    metecem Friend of Leo's
    berlin,now in Istanbul
    If in doubt, make a 3 piece neck. Laminated necks are stronger and surely won't need a truss rod for your purpose.
    My 4 string baritone electric ukuleles never have truss rods.
  3. ebb soul
    Smyrna georgia
    Martin didn't think ANY of their guitars needed a truss for 50yrs or more.
  4. mudimba
    mudimba Tele-Meister Ad Free Member
    California
    Do you want any relief when it is strung up? I don't know if truss rods are for strength as much as it is much easier to level frets flat than to carve relief in.
    Some 6 string guitars are made without a truss rod, so you certainly don't need one, but setup is easier if you can make minor adjustments to relief without a file.
  5. ebb soul
    Smyrna georgia
    Fret crown the relief in.
  6. guitarbuilder
    guitarbuilder Telefied Silver Supporter
  7. jayyj
    jayyj Tele-Afflicted
    Manchester, UK
    I made a few tenor guitars with an aluminium bar in the neck for reinforcement. It worked well but was not really much of a saving over putting in a two way trussrod.
  8. Zepfan
    Zepfan Poster Extraordinaire
    Horn Lake, MS
    Depends on what wood your making the neck from. As long as your not using Pine or similar soft wood, then probably no need for a trussrod on a 3 stringer at that scale length and using light gauge strings. Would recommend using at least 2 pieces(1 for the neck and 1 for the fret board) glued together for the neck.
  9. Veebus52
    Veebus52 Tele-Meister
    Bartlesville, OK
    I've made a number of cigar box guitars using 1 X 2 piece of oak for the neck, which actually is .75" by 1.5". No issues with the neck bending or staying in tune. Of course, I don't set them up with a very low action either.
