DOD 280 Compressor Problem
Discussion in 'The Stomp Box' started by eddiewagner, Mar 26, 2020 at 2:53 PM.
  1. eddiewagner
    eddiewagner Poster Extraordinaire
    ROCK!linghausen/germany
    Hi guys, I just bought a very little used 280, new model. It sounds great but when I switch it on, it makes bad crackling noises, that fade away after a little while. What do you think?
  2. cometazzi
    cometazzi Tele-Meister Silver Supporter
    Das Land von Käse und Bier
    Does it do this when you switch it off also?
    Does it make these noises when you jiggle the cables plugged into it?
    How about if you jiggle the stomp switch?
    Don't press it, just see if it or the moving part is loose and makes that noise.
    'crackling' is quite often a bad or dirty connection.
    zippofan and eddiewagner like this.
  3. eddiewagner
    Thanks man. I will do more inspections. I have feeling it needs more electric power than an overdrive
  4. E5RSY
    E5RSY Doctor of Teleocity
    Georgetown, TX
    I have four pedals in this series and the only one that I bought used had some switch issues briefly. It was the OD-250. Was playing it onstage once and when I clicked it OFF my entire signal went dead. Turned out it was the switch. I simply sprayed the switch with a little de-oxit then put it on the floor where I cycled it ON/OFF about 50 times. Problem solved. Hopefully that'll work for you, too.
    eddiewagner likes this.
  5. eddiewagner
    Hallelujah! It’s healed. I put it on for a couple of hours and kicked the switch many times. The sound of that thing for Slideguitar is amazing. Instant Lowell George sort of.
    E5RSY likes this.
