Do you use a compressor?
Discussion in 'The Stomp Box' started by dsouza, Oct 14, 2019.
  1. Fearnot
    Fearnot Poster Extraordinaire
    Decatur, GA
    I have a DOD Milkbox that I only break out when I'm playing 12-string. Beyond that, no.
    boppy likes this.
  2. Telecaster88
    Telecaster88 Tele-Afflicted
    Midwest USA
    I have a Maxon, but knew I really wanted a Dyna Comp. I ended up with the Deluxe Dyna Comp cuz it has the same circuit as the Script model, but added tone and blend knobs, all for $10 less than the plain Script!
    Honestly I just have all four knobs at 12 o'clock and it gives me that sparkle and definition I love, no fuss. It's the kind of thing you don't even know it's on, besides everything sounds so good. Switch it off and something's missing. That something is the "Dyna Comp Magic®."
    lespaul74 likes this.
  3. Marc Morfei
    Marc Morfei Friend of Leo's Silver Supporter
    Wilmington, DE
    There have been threads like this before.
    50% of people: OMG yes, what's wrong with you, of course you need a compressor.
    50% of people: Compressor? Huh? No. What for?
    stevemc and Telecaster88 like this.
  4. RetroTeleRod
    RetroTeleRod Poster Extraordinaire
    Oklahoma, USA
    I like a compressor for certain things. I tend to go back and forth on whether I need one or not. Just put my CS-3 back on board, so at present I'm in the compressor camp.
    MilwMark likes this.
  5. telemnemonics
    Not in a pedal but most of my amps provide some tube compression even clean, and most of my dirt pedals compress as well.
    Playing clean through a big clean amp turned down you might have more need for a comp pedal, or not.
    Fingerpicking also might make a comp pedal desirable to help each finger produce the same volume.
  6. graybeard65
    graybeard65 Tele-Meister
    Rochester, MN
    I’m the odd duck that’s really on the fence. I’ve owned both the two- and the four-knob Keeley, a wampler Ego, and very recently a dyna-comp. I really want to like them, and try to find a set-it-and-forget-it sweet spot...but find that it just doesn’t work for me consistently.
    As others have said - for chicken pickin and the occasional Gilmour/Steely Dan jaunt, I really like what the comp brings to the party. For other things, I really miss the very dynamics that the compressor tames.
    so - have one, but only use it infrequently. Have decided that it’s equal parts style, and operator error.
  7. tlsmack
    tlsmack Tele-Afflicted
    Lonk I-lant, New York
    I find a little compression helps me hit any chord anywhere on the neck with confidence. Especially when playing clean. I have an EHX tone corset, the blend knob helps me even things out.
  8. Pajama
    Pajama Tele-Meister
    I use an Xotic Sp on the lowest setting. I like it for clean and fuzz but turn it off when going through overdrive.
  9. zeedoctour
    zeedoctour Tele-Meister
    yes
  10. Buzzgrowl
    Buzzgrowl Tele-Meister
    Switzerland
    It's nice to imagine you don't need one or that it negatively affects playing dynamics.... but the truth is that most players and bands benefit from all-round compression on most instruments. When you are standing next to your amp, you don't hear your dropouts as well. But the band and audience may have a different impression. Live, the sound engineer will habitually compress or limit you. Along with the snare, kick, bass and vox.
    Compressor pedals definately makes riding the volume control on your guitar less useful, even useless. For a few songs I turn it off. But it usually stays on and I use pedals to boost volume and gain. I wish I could just ride the volume pot for our whole gig set.
    Next partscaster will have a selector for "normal" and "bridge hb tone & volume pots bypassed" and see how that works. Anyone try this?
    Having said all this, I really like the sound of my old cs2, clean or pushing an old rat. Add some delay and you are a guitar hero!
  11. Tornado
    Tornado Tele-Meister
    Amsterdam
    I use it a lot on my clean sounds. I think it improves the tone. I also use it in front of a distortion or overdrive pedal to make my overdriven sounds smoother and to get more presence. The compressor pedal I use now sounds bright and doesn't squash the sound completely.
    I also like the compressor in my Boss ME-5 multi effect.
  12. ping-ping-clicka
    ping-ping-clicka Poster Extraordinaire Ad Free Member
    left coast
    Yes , I do use a compressor in several different flavors. The Pedal that I use is the Boss CS-3, the the digitech GSP 1101 has three different versions of compression including the BossCS-2 and the Dynacomp compressor ( based on the mxr dynacomp) and a very nice generic compressor . I own the FMR Audio RNC (REALLY NICE COMPRESSOR ). This unit has been reviewed as being comparable to the DBX 160.
    COMPRESSION ADDS A CERTAIN SOMETHING WHEN USED
    Telecaster88 likes this.
  13. stevemc
    stevemc Tele-Afflicted
    cape cod
    i have a cs3.i can still use the volume knob to clean things up.
  14. telepraise
    telepraise Tele-Afflicted
    Tampa Bay
    This is my experience precisely with a Wampler Ego. I rarely turn up the sustain, just enough attack to catch some tele spikes and the blend stays at 12:00. When you turn it off, things sound dull.
  15. bumnote
    bumnote Tele-Holic Ad Free Member
    Northern Virginia
    Yes...not a lot but quite a bit. I have an original run '73/'74 Dyna Comp that's really versatile. They ain't cheap, but I found one who's seller, and myself at the time, wasn't fully aware about what is was worth so it was almost theft. I got rid of my others as a result...then on a whim bought the Joyo JF-10. Very subtle, clear but not a lot of squash...and dirt cheap. If you're new to compression pedals, it's a good place to start, they run $30-40 new. If you've never used one, start cheap to see if it's something you'd really use. No sense in starting off with a $100+ pedal that 50% of guitarists like, and 50% don't.
    There's a simple mod you can do by drilling a hole into the case that allows an internal trim pot to be adjusted.
    Explained here....
    https://www.thegearpage.net/board/index.php?threads/joyo-dyna-compressor-jf-10-easy-mod.1471040/
    Unfortunately I didn't save the picture showing the mod. I haven't done it yet, but I am next time I have my drill out.
    A TDPRI thread on the JF-10
    https://www.tdpri.com/threads/joyo-jf-10-dynamic-compressor-thoughts.317013/
  16. schenkadere
    schenkadere Friend of Leo's
    NY
    I always come back to a compressor. Currently using the Mooer Yellow Comp set all at noon. I really like comps with SS amps to add some warmth, liveliness and bounce...set not as subtle.
    57fenderstrat and RetroTeleRod like this.
  17. Charlie Bernstein
    Augusta, Maine
    It's not a must. It depends on how you want to sound.
    For blues, which is what I like playing, they can do more harm than good. I never had any luck with them until I got one with a blend knob. I just leave all its knobs at noon and forget about 'em. It adds sustain without sucking out the soul.
    Nice but not essential. I might even replace it with a same-size boost pedal - also nice but not essential.
  18. radiocaster
    europe
    I don't use it, but a few weeks ago I tried it with a distortion or fuzz that wasn't high gain, and got crazy metal high gain sounds.
  19. Butch Snyder
    Butch Snyder Tele-Afflicted
    St Augustine, FL
    I own one and it stays on all the time.
  20. ndcaster
    ndcaster Doctor of Teleocity
    Indiana
    what do you use for vocals?
