BobbyZ
When using the shunt method, both meter probes are hot with plate voltage and you've got to control both of them carefully to prevent shorting the plate to ground or shocking the piss out of yourself.
Yeah that little really hard to change 1/2 amp fuse inside the meter will blow if you even think about touching the probe in the wrong spot.
But that little &^/#/&** won't blow if you're shocking the piss out of yourself !
Of course I still use the shunt method. Lol
