Do you lube your vintage style tuners?
Discussion in 'Tele-Technical' started by Fretting out, Jul 7, 2020.
Tags:
  1. Yes
    18 vote(s)
    37.5%
  2. No
    28 vote(s)
    58.3%
  3. Shelled amphibians
    2 vote(s)
    4.2%
  1. Fretting out
    Land of Mary
    as the title implies
    I myself do, I have a bottle of lube with a needle tip that fits perfectly in the hole in the back of those tuners
    Is there any reason to do/not do this?
    marc2211 likes this.
  2. teleplayr
    teleplayr Tele-Afflicted
    Nicoma Park, Oklahoma
    I use lithium grease and a small syringe.
  3. Viejo
    Viejo Tele-Afflicted Silver Supporter
    Central IL
    Every 4th string change they get a small shot of Big Bends Nut Sauce
    porto leone and gitold like this.
  4. radiocaster
    europe
    You can also do it on enclosed ones by squirting WD40 into the shaft. I only do it if one of them is not turning smoothly.
    Fretting out likes this.
  5. Fretting out
    Land of Mary
    Uh-oh better not let anyone see you use WD40! ;)
    There’s a big anti-WD40 group around here
  6. radiocaster
    europe
    I also wouldn't use it in potentiometers and switches.
    Gevalt and RyCo1983 like this.
  7. beagle
    beagle Friend of Leo's
    Yorkshire
    WD40 is not a lubricant. It washes away any grease in the tuner, leaves a horrid sticky deposit behind when it evaporates and melts plastics.
    porto leone, iBloke, Matthias and 8 others like this.
  8. JIMMY JAZZMAN
    JIMMY JAZZMAN Tele-Meister
    Baltimore
    Beagle is right. If you lube, go to a jewelry shop. They'll have the right stuff. WD40= door jambs, hinges not
    guitars. NEVER.
    porto leone likes this.
  9. radiocaster
    europe
    I don't think I have any tuning machines with plastic gears.
  10. beagle
    Yorkshire
    Many tuners have plastic bushes and washers that you can't see. WD40 is designed to displace water.
    Gevalt and suave eddie like this.
  11. marc2211
    marc2211 Tele-Holic
    Switzerland/France
    Uh oh. I don't and I probably should do. I am about to change tuners on my Strat after 25 yesrs service, as they have become a bit stiff and grindy... now I'm wondering if they just need a bit of grease? Hmm.
    fenderchamp and Fretting out like this.
  12. Fretting out
    Land of Mary
    I’d give it a try, sometimes they need completely disassembled then lubed but I don’t think it would hurt to give it a try, I think all parts actually sells a tuner lube that comes in a bottle with a needle so you can get in the back, I got some lube from the guitar store, I think it’s used for drum hardware but so far so good
  13. J. Bonkosky
    J. Bonkosky TDPRI Member
    Seattle Washington
    I never have lubericated Gotoh or Kluson style tuners. But I can see both have a synthetic high temperature Non melting lubricant that should last decades. I wouldn’t bother lubricating these tuners with anything except a similar product to what was used from the factory.
    I would recommend avoiding light oils (sewing machine oil, gun oil, engine oil, etc...). Lighter oils will leak into the surrounding wood and over time And may damage the finish or the wood. They will also collect dust and compound any sticking tuner issues. WD40 will in some instances damage plastics as it does contain primarily solvent. Also not great for a finish if left on. In the end it is your stuff, do with it what you like. YMMV
    Wallaby, Ebidis and Fretting out like this.
  14. gmann
    gmann Friend of Leo's
    Okinawa, Japan
    So far I haven't felt the need to. I would tho, but not with WD-40.
  15. ArcticWhite
    ArcticWhite Tele-Holic
    Portland Oregon
  16. J. Bonkosky
    Seattle Washington
    If it is on a stewmac tutorial I would follow that. Vaseline is great stuff and inexpensive. I would also look at Loctite #36781 (NLGI #2 rated with a 500 degree dropping point) or superlube synthetic multi purpose grease with Teflon. I use the superlube on my ratchets for work. That stuff stays put very well and resists wash out with solvent.
  17. Ian T
    Ian T Tele-Afflicted
    Tampa Bay
    I have been playing 35 years, never oiled my tuners, and never had the need. But if your tuners are feeling rusty, sure, why not. Just make sure it is safe for plastic. I have a Teflon grease syringe for plastic that I'd use for that.
    porto leone and Dismalhead like this.
  18. marc2211
    marc2211 Tele-Holic
    Switzerland/France
    I have an aerosol can of spray lubricant 'with vaseline'. I squirted this in through the small holes in the back of the tuner. Much much better - this thread made my day! :D
    gregulator450 and Fretting out like this.
  19. stefanhotrod
    stefanhotrod Tele-Holic
    germany
    Pure vaseline is a superb tuner grease. WD40 not, because it‘s no grease :D
    It‘s a good idea to lubricate your Kluson style tuners for sure. Too much won‘t hurt, too less means bad working.
    porto leone and Fretting out like this.
  20. E5RSY
    E5RSY Doctor of Teleocity
    Georgetown, TX
    Gevalt likes this.
