Do you have both an Analog and a Digital Delay on your Board?
Discussion in 'The Stomp Box' started by RetroTeleRod, Mar 27, 2018.
  1. FilthyFur74
    FilthyFur74 Tele-Holic
    Yorkshire, UK
    I had a Strymon El Cap and a EHX DMM 1100 on the board but the Meris Polymoon evicted them both.
    RetroTeleRod likes this.
  2. RetroTeleRod
    RetroTeleRod Poster Extraordinaire
    Oklahoma, USA
    Actually, 7 Korg Miku's...and a tuner.
    artdecade likes this.
  3. x2plex
    x2plex Tele-Meister
    Calgary, Canada
    As with OD pedals, I use different delays for different applications, but rarely at the same time.
    On my board, I hit the OCD upstream of the MXR compressor but the OD3 downstream. Trem comes next. The photo doesn't show it, but I run out to a VP Jr volume pedal that sits closer to my playing position which lets me ride the throttle without changing my basic sound. Then I loop back to the time-based effects, ending with reverb that's almost always on. The DD-7 and reverb are both able to do stereo so I do that whenever I can get away with it. BTW, my Carbon Copy is really fussy about power so I ensure that it gets exactly 9V of clean isolated juice. IMG_1728.JPG
  4. JDB2
    JDB2 Tele-Meister
    Arizona
    @x2plex How do you like the MXR Studio Compressor? Did you try others before settling on it?
  5. x2plex
    x2plex Tele-Meister
    Calgary, Canada
    I like it a lot. I like to control the timing of onset and release because I can emulate power supply sag and that ethereal 'bloom' thing. It's also nice to have separate input and output level controls so can I can tame that 18V OCD in manageable steps.
  6. bluesholyman
    bluesholyman Tele-Afflicted
    Greater Atlanta
    I am running a Red Panda Context Reverb on the +Delay setting in my effects loop - nice Verb-Delay combination that I have on all the time.
    In front just before the amp after all other pedals is an Ibanez DE-7 that I am now using for the more spacial soaring lead type stuff - it gets washed down a bit with the Verb-Delay in the loop and ends up being quite nice and wide.
    I tried a couple different analog delays and as much as I tried to like them, I think I prefer warm digital delay after all....
  7. Knowcaster
    Knowcaster Tele-Holic
    Pittsburgh, PA
    Not exactly - but my digital delay (Hardwire DL-8 Delay) has an "analog" setting. Does that count?
  8. Paul in Colorado
    R.I.P. 2019
    Let's see now. No analog delays ever unless an actual Space Echo counts. A DigiDelay on one board and a Boss DD-2 on the other. In the amp loop I have either a TC Alter Ego V2 or a Zoom MS 70CDR. I use one delay for short slapback repeats and the other for the longer echos. Sometimes both at the same time. I like a little ambience and I like to get psychedelic from time to time.
  9. Thin white duke
    Thin white duke Tele-Afflicted
    italy
    I've got the danelectro pb&j delay dj 17, it's very analog sounding but it's digital, there is a switch that if you push it you can change delay type, one is for slap back, one for longer delay, very cool idea.
  10. Pepi
    Pepi Tele-Afflicted
    Indiana
  11. DeVilleDude
    DeVilleDude Tele-Holic
    Hilton Head Island, S.C.
    Replica and Alter Ego v2. Replica gives me a glorious sounding digital, plus emulates an un-modulated analog well. AE gives me a spectrum of modulated analog delays. The 2 cover my needs well.
  12. Mincer
    Mincer Tele-Holic
    Tampa Bay Area
    I use a Vapor Trail for analog (occasionally with effects in the delay loop), and a DL-4.
