I used to use Titebond, and switched to CA 10 years ago.
I've never done frets but I would think glue would make them harder to change out and run the risk of chips and splinters if they ever had to be pulled? Am I wrong on that thought i.e. how does one pull the frets without damage?
It is virtually impossible to remove frets without any damage to the slot. The teeth on the tang just about guarantee this. I heat the frets to soften whatever crap may be holding them.
I don't use glue for new fret jobs.Thanks guys,
Just to clarify I was referring to a brand new fretting jobs, not re-frets, which assumes the fret slots are in pristine condition.
Glue your frets is a no no.
What you do after removing the frets is run moist rag trough the the slots, when you do that way you lift up the fiber in the wood preping it to grab on to fresh frets. You shrink the slots.
Once you get glue in there you ruin the wood forever.
I just dab a little CA in the fret ends.
Use glue if you install Stainless Steel frets, maybe.. but even then.. nah.
I also have never used any for re-frets but acknowledge it might be called for under certain situations. I've maybe not done enough of them to have needed it.
