Do string-through design guitars keep their tuning better?
Discussion in 'Tele Home Depot' started by Verzila, Jun 17, 2019.
  1. Verzila
    Verzila Tele-Meister
    WR15 8PH, United Kingdom
    i’ve got two string-through types, a telecaster and one with a tune-o-metic and body ferrules. Of all my guitars, these two seem to keep tune better than the others (tune-o-metics and stop tails, wrapover bridges).
    I know there are many other factors at play when it coms to tuning stability but I just wonder if this is partly down to the string-though design, or is it just coincidence?
  2. Fluddman
    Fluddman Tele-Meister
    Sydney, Australia
    I'd be inclined to think the main issues would be at the headstock end of the guitar.
    Cheers
  3. Nick Fanis
    Nick Fanis Friend of Leo's Ad Free Member
    Athens-GREECE
    No they don't.
    Treadplatedual and rangercaster like this.
  4. stefanhotrod
    stefanhotrod Tele-Meister
    germany
    Tuning issues are in most cases poor stringing and/or a poor slotted nut. Third suspect is the bridge.
  5. rze99
    rze99 Poster Extraordinaire
    South London UK
    As the owner of many types of guitars, no.
    Tuners, stretching strings thoroughly and nut cut / lube are top of my list.
    Old Deaf Roadie likes this.
  6. bettyseldest
    bettyseldest Friend of Leo's
    Other than Teles the only through body strung guitar I have is a Patrick Eggle New York. Despite a pretty straight string pull at the head it needed a nut lube to give it tuning stability.
  7. brookdalebill
    Austin, Tx
    This, IMO.
    A straight string pull behind the nut is helpful.
    I have String Butlers mounted on a few of my guitars.
    They help keep the guitar in tune.
    nojazzhere likes this.
  8. Musekatcher
    Musekatcher Tele-Afflicted
    meridianam altum centralis
    One thing to consider, is pitch discernment. Some instruments are more easily tuned because you can hear and feel the pitch more precisely, and therefore you can tune it quicker, and more reliably. You can readily hear the difference in a couple cents difference, so that dissonance stands out. You tune till the dissonance goes away. Your string-thru's may have a more stable, clearer response, allowing you to more easily hear and tune them more precisely. As an opposite example, some banjos, and some older guitars are really hard to tune precisely, because the pitch is not as easily heard or identified. A few cents difference around the pitch you want, is difficult to hear. There appears to be dissonance below, on and above the target pitch. With these instruments, you aren't really ever convinced you have them precisely tuned. You walk away, and come back later and pick it up, and it sounds out of tune now - when the instrument wasn't in tune before you walked off. Your ears got a rest, and can now hear the dissonance better. That inability to present a good pitch with precision leads to ear fatigue, worsening the ability to tune.
  9. Old Deaf Roadie
    Old Deaf Roadie Tele-Holic
    Oregon
    I have never experienced a tuning issue on any guitar that wasn't related to the tuning machines slipping under tension. I have seen Lester's with an unstable Tune-o-matic that won't hold tune, though. Any solid tailpiece should work to your benefit, whether it be thru-body or a stop-type.
  10. tfarny
    tfarny Friend of Leo's
    Hudson Valley, NY
    90% of tuning stability is the strings not being able to move freely in the nut. Widen the slots and apply lube - as simple as graphite from a pencil - and you'll solve tuning issues on almost any guitar. Straight string pull helps as well, which is a reason Fenders stay in tune better than Gibson, but that ALSO has to do with the string moving in the nut.
    Almost all cheap tuners work fine, and trem systems can be made pretty stable, but the strings can't be tightly seated in the nut slots or you will continually have problems.
  11. jvin248
    jvin248 Poster Extraordinaire
    Lions & Tigers oh Mi !
    There is tuning stability playing, with a trem or bending strings. Which I think most of the prior responses are aimed at.
    There is tuning stability from temperature and humidity fluctuations. Which is the construction style I think you are more going after.
    I find the latter is mostly due to all-maple necks are more stable than mixed wood necks like rosewood/ebony. All maple necks also have full finish on them while rosewood/ebony are only oiled and left open pores for humidity to move in them.
    18 inches of wood flopping back and forth under temperature and humidity swings causes a guitar to drop tuning.
    Through body adds another section of lumber that can expand and contract with humidity. I mostly hate through body for having to flop the guitar carcass back and forth at string changes like a dead fish. Top loaders are my favorite.
  12. Obsessed
    Montana
    I have never experienced a difference and as others chimed in, there are other areas of the guitar that have way more effect on tuning, but theoretically, it probably is true that string thru is more tuning stable, because of less parts involved. The KISS strategy in engineering design usually prevails. @jvin248 just gave another example of the KISS design of solid maple necks. Perhaps this is why some of us refer to our teles as the basic tool. We know that Keef has shown how robust it is on stage:
  13. SacDAve
    SacDAve Poster Extraordinaire
    Rocklin Ca.
    I found cheap tuning machines to be the #1 cause of going out of tune. I always like to use locking tuners on my guitars I prefer Sperzel I just like the feel of them.
  14. rangercaster
    rangercaster Friend of Leo's
    portland, or
    My understanding and most others is that even the cheapest functional tuning machines will provide adequate stability ... You can put a $200 set of titanium alloy locking tuners on a guitar with a bad nut and it won't tune properly ... It's your money ...
    I_build_my_own and nojazzhere like this.
  15. mistermikev
    mistermikev Tele-Holic
    phoenix
    I would think string thru has little to no effect. in my experience the nut is often the source of tuning issues. if we are talking about a fixed bridge... nut, tuners, then saddles/bridge, then rigidity of the neck/headstock.
    If we are talking tremolo... I just learned something recently that allowed me, for the first time in my experience, to float a six screw bridge, do divebombs, and actually stay in tune ALMOST perfect... and that was the carl verheyen setup.
    Thought I knew everything but the more I know the less I know I know.
