Do pickups lose quality over time?
Discussion in 'Tele-Technical' started by dscottyg, Apr 14, 2021.
  1. dscottyg
    dscottyg Tele-Meister
    Jacksonville
    A89B2D0A-4269-4D62-94B1-89C940DAF77F.jpeg E35DE40A-A3C3-4DBB-9EF2-E8B61EA57429.jpeg I just got a set of used Custom Shop Texas Special Telecaster pickups for $130 to restore a 2001 American Designer Edition Silver Sparkle. They look pretty old. Should I have spent the extra $60 for brand new? I know the typical responses will be “Try them and see if you like them.” Unfortunately I don’t have a discerning ear, but it will feel better knowing that they are sounding as good as new ones would. Thanks.
    Arfage likes this.
  2. Tele-friend
    Tele-friend Tele-Meister
    EU
    I am not an expert on old pickups but as far as I have heard in an interwiew with Mr. Seth Lover (or maybe a documentary about him) their magnetic properties change over time. They become little 'weaker' to simplify it and this is something that many people actually like. So if for example you want to recreate an older pickup, you can use less windings. At least this is my understanding about the topic.
  3. northernguitar
    northernguitar Friend of Leo's
    North of Toronto
    I have an early 70s Pat No. Gibson T-Top. Sounds like it did when I first played on it, 25 years ago.
    stepvan, dodona, igor5 and 3 others like this.
  4. aadvark
    aadvark Tele-Meister
    melbourne
    mine are 69 years old, still sound amazing...
    but to specifically answer your question, maybe if they lose a little signal (not necessarily a bad thing - I love low output pickups - because I can drive the amp/valves harder) it will take a long time, I can't see that there'll be any noticeable difference in yours.
    Clean them up, put them in and "see if you like them"!
  5. bgmacaw
    bgmacaw Poster Extraordinaire
    Near Athens GA USA
    Material science says a permanent magnet will lose less than 1% of its magnetism over 100 years provided they haven't been subjected to significant environmental stress or physically damaged.
    Guitar mojo says a pickup magnet will sound better if it's older, as long as it isn't a ceramic pickup, unless it is a rubber magnet with a gold foil covering.
  6. Nick Fanis
    Athens-GREECE
    What is "pickup quality" and how can you "loose" it?
  7. DADGAD
    DADGAD Friend of Leo's
    Earth
    If your guitar pickup never gets hot, cold, bumped or placed anywhere near an amp speaker, magetic tipped screw driver or soldering gun, you will have no problem with the magnet getting weaker.
    Geo, El Tele Lobo, beep.click and 5 others like this.
  8. Matthias
    Matthias Friend of Leo's Gold Supporter
    Third rock from the Sun
    After about 20 years? None of mine over that age have issues.
    Sometimes you can get mechanical problems in the wires and solder joints on really old pickups... I'll refer to @Wally's post here: https://www.tdpri.com/threads/helping-a-friend-sell-a-strat.1068690/page-2#post-10596757
    But I would expect yours sound the same as they did went made. I see no rust on them, just dust, and it's the corrosion that does for them. The magnets getting audibly weaker over a few decades is debated, but I believe other things could affect them, such as how you store the pickups if they've been separated from the guitar... The magnets can effect each other.
    StarRaider likes this.
  9. Wally
  10. Telecentric
    Telecentric Tele-Holic
    Boulder Creek, Ca
    Some pickups do become microphonic, so something is affecting them. Most don't or at least I have not run into that problem on a guitar I have owned for any significant time.
    Wally and nojazzhere like this.
  11. DrBGood
    DrBGood Tele-Holic
    Sutton QC, CANADA
    If they did, '59 Les Pauls would be firewood.
    LesTele, Deeve, willholt92 and 9 others like this.
  12. mkdaws32
    mkdaws32 Friend of Leo's Gold Supporter
    Moncton, NB Canada
    Usually a pickup will become microphonic because the windings are vibrating. Maybe whatever it is potted in has broken down over time, or the windings just relaxed a bit over time to vibrate a bit. I find a slightly microphonic pickup sounds more "airy" and lively - but too much and it's just squealing and feedbacking all the time, which is no good. I don't think magnet strength has anything to do with microphonics, but if an expert can explain otherwise, I will concede ;)
    DCCable and Wally like this.
  13. jvin248
    jvin248 Doctor of Teleocity
    Lions & Tigers oh Mi !
    Materials all age and get brittle. Abuse, neglect, and damage can degrade their performance.
    Leave a guitar in a hot car and the wax potting may melt/evaporate/move around or a cold car it may crack and allow the wires to vibrate and squeal under high gain. Leaning a guitar next to a cabinet full of high power magnets or transformers can alter the pickup magnets.
    The largest factor that people care about are Alnico magnets lose strength naturally over decades, a known and well documented event. Ceramic magnets remain identical over time to the day they were made. So by 'Quality' standards you should choose ceramic magnet pickups like the ones found in Squiers and some older MIM Fenders. Vintage purists demand Alnico because that's what the guitars in the 50s were built with.
    You'll see references where Alnico V pickups have 'deteriorated' to Alnico II or III strength. And hence why some boutique pickup winders make new pickups with Alnico II/III to market to those chasing more of a 'vintage vibe'. You can 'recharge' Alnico pickups. I've seen a few instances where one alnico pole had lost it's charge out of a set and a recharge fixed the pickup.
    You can achieve the same output between typical pickup magnets by adjusting the pickup height. Don't use published pickup height specs that were developed for brand new Alnico when setting up your Ceramic magnet pickups. Put the Ceramic magnet pickups lower. Even just an eighth inch height adjustment can change the tone. So use your ears and magnet type becomes meaningless.
  14. northernguitar
    North of Toronto
    Five decades on my alnico V T-Top. No changes.
    StarRaider, dscottyg and JRapp like this.
  15. Boreas
    Boreas Friend of Leo's Silver Supporter
    Adirondack Coast, NY
    Many people feel they get better with age. Obviously, a few can fail or develop problems, but typically they don't change much. It is just as likely your hearing or amp will change more than the pickups.
  16. darkwaters
    darkwaters Friend of Leo's
    Newfoundland
    I wouldn't worry about it.
    aging_rocker and northernguitar like this.
  17. Boxla
    Boxla Tele-Meister
    Jahmerica
    Jerry Garcia, who I would argue had good ears when it came to tone, was 100% convinced that pickups degrade over time and that's why he would change his out.
  18. Lucius Paisley
    Lucius Paisley Tele-Afflicted
    Sydney, Australia
    Yeah, but it's Jerry Garcia. Degradation wasn't the issue. At least, not of the pickups.
  19. Killing Floor
    Killing Floor Tele-Afflicted
    Austin, TX
    Magnetic metals will decay over time. Whether it is significant such that you would notice is not as likely. It’s more likely that you’d notice the difference in the same type pickups with variations in turns or wiring pattern.
    Not debating the physics of Faraday’s Law or half-life. But the forces required to demagnetize would certainly be equivalent to the forces required to magnetize the pole pieces. So normal use and storage won’t flip a switch, so to speak.
    Winding technique and material plays a role. Vintage pickups were wound by hand (Ok, hand operated anyway) and counting and density/compactness and crosses were not as carefully controlled. Turns out many collectors and tone chasers dig that. So we might pay a premium for “scatter wound” which would make an engineer cringe. That said, 2 scatter wound pickups are not exactly the same. 2 machine assembled, numerically wound pickups wound be identical. So don’t discount that this is what people seek and seem to recognize.
    If string over pole can generate 200 mV (example) a 1% loss over 20 years (also example) is 196 mV. That’s within the tolerance of your pots on your guitar and in your amp. Just saying it may be something but don’t toss those sweet pickups just yet.
    nojazzhere and northernguitar like this.
  20. nojazzhere
    Foat Wuth, Texas
    I think it's a fact that pickups CAN change with time. The question is whether that change is for the better or worse.
    I've read interviews with guitarists (particularly Jim Campilonga) who said one day they put their guitar away after playing, and the next day a pickup had simply died. As far as saying a pickup hadn't changed over forty or fifty years, it could just be that the change was so gradual that you wouldn't discern the change.
    BlueGillGreg and Tele-friend like this.
