do magnets and pots play nice together?
Discussion in 'Tele Home Depot' started by Meteorman, Apr 11, 2021.
  1. Meteorman
    Meteorman Tele-Afflicted
    State College PA
    Needing to improvise a control cavity cover attachment system under small, tight, crowded conditions.
    The normal lip/shelf route does not exist - nor can it.
    One possibility is 2 small (4mm) round magnets epoxied to the bottom of the cover, which would stick to the 2 pot backs, thereby holding the cover in place.
    Would the magnets compromise the function of the pots ?
    thanks
    /mike
    crazydave911 and Boreas like this.
  2. Boreas
    Boreas Friend of Leo's Silver Supporter
    Adirondack Coast, NY
    One way to find out!! Try it and get back to us!
  3. guitarbuilder
    Don't know the answer but if you have room for a couple pieces of truss rod leftovers or (3/16 steel rod)...they would not take up too much real estate and would be attractive to a couple magnets. You could drill for them and epoxy/super glue them into the control cavity. Just an idea anyway.
    crazydave911, hepular and Meteorman like this.
  4. Digital Larry
    Digital Larry Friend of Leo's
    Silicon Valley, CA
    Really doubt it would be a problem.
    crazydave911 and Meteorman like this.
  5. SRHmusic
    SRHmusic Tele-Holic Silver Supporter
    North Carolina, USA
    Magnets should not have any effect on a potentiometer. The only thing I could think of is if there's some pull on a steel part that adds a little mechanical stress.
  6. Ronkirn
    Ronkirn Doctor of Teleocity
    Jacksonville, FL
    no problem. unless the carbon film in the pot has figured out a way to become magnetic..
    r
  7. Peegoo
    Peegoo Poster Extraordinaire
    Between the Raindrops
    No, there will be no interaction at all.
    The pickups make a much larger magnetic field than a 4mm disc magnet will.
    AAT65, crazydave911 and Meteorman like this.
  8. Meteorman
    State College PA
    Thanks gents.
    I shall give it a go.
    crazydave911 likes this.
  9. RolandG
    RolandG Tele-Meister
    I’ve started using 1mm deep neodymium magnets held in place with cyanoacrylic glue. Neodymium has a far stronger magnetic field than traditional ferrite magnets.
    Just make sure that you get the magnets the right way round. I use a brad pointed bit drill to indent both the body and cavity cover by 1mm, put a drop of glue in each of the body indents, and drop two magnets on top. Then I put a drop of glue into the cover indents, and put the cover in place.
    photondev likes this.
