Do i wire toaster pickups like a humbucker or single coil?
Discussion in 'Just Pickups' started by markfresh, Apr 21, 2020.
  1. markfresh
    markfresh TDPRI Member
    ipswich qld
    HI,
    I bought some cheap toasters for a cheap guitar.
    Do i wire them like single coil or humbucker?
    They have 2 wires which i imagine the shrouded one is hot and the un-shrouded the ground.
    I have read mixed ideas of if they are HB or SC.
    I have wired them as humbuckers and only the bridge seems to work.
    Please see linked diagram,
    Also can i check that on the tone pots that the far right tabs are left unsoldered and the capacitor connects only to the middle.
  2. markfresh
    ipswich qld
  3. radiocaster
    europe
    You have some imagination.
    There is no such thing as humbucker wiring, you can just as well wire single coils with the pdf you enclosed. Some people wire a different value of pots for tonal reasons, but it would work like that as well.
    Also, the shrouded part is the ground/earth, the unshielded part is the hot. I assume by shroud you mean the braided metal wrap.
  4. rigatele
    rigatele Tele-Afflicted
    Are they from a "discount" mail order vendor from China for example? The ones I tore apart were HB with dual mini HB bobbins with ceramic magnets inside, instead of steel blades and a single magnet.
  5. markfresh
    ipswich qld
    They are from ebay in australia, no name brand.
  6. Fearnot
    Fearnot Friend of Leo's
    Decatur, GA
    If they're anything like the cheap toasters I bought, they're just cheap, overwound ceramic minihumbuckers under the covers. I might use them someday, but not in any guitar I really care about.
    They look nice.
    EDIT: Curtis Novak used to offer to drop a 'real' toaster under these covers for something like $60. I really should've done that.
    trancedental likes this.
  7. markfresh
    ipswich qld
    Yes they do look nice and also different, i might take them apart and have a look, maybe one is just faulty and will become a paperweight, and yeh they sre just going in a cheap diy guitar.
  8. rigatele
    Strange. The ones I got were the most underwound I've literally ever seen.
  9. markfresh
    ipswich qld
    So after all that its a faulty switch, wish i checked that earlier .
  10. stratisfied
    stratisfied Tele-Meister
    Midwest
    The hot will be the insulated inner wire. The surrounding braid is the ground.
  11. tele_savales
    tele_savales Tele-Holic
    Brooklyn, Joey!
  12. Ronkirn
    Jacksonville, FL
    to answer your question. Yes, wire them just like any other two lead pickup...
    r
  13. trancedental
    trancedental Tele-Meister
    London
    The MIC & at least some of the MIK toaster lookalikes are actually Firebird type mini humbuckers with rail magnets inside each bobbin. I'm not sure about the Kent Armstrong toaster lookalikes.
    They sound OK but nothing like a toaster type.
    If you want a toaster type pup, you can use a plastic P90 bobbin, first cut / sand down the edges to fit inside the cover, then drill out the Pole Bolt holes to fit 6mm or 1/4" (6.35mm) Alnico 5 rod magnets. Don't drill all the way though the other side of the bobbin. Glue in the A5 rods.
    Wind the bobbin with 44AWG pup wire from 6.5 to 8-5K Resistance, to get the 50-60's vintage sound, up to 12K for more modern tones.
    radiocaster likes this.
