Do I neeeeeed a PR and DR and VR?
Discussion in 'Amp Central Station' started by corliss1, Sep 6, 2019.
  1. corliss1
    Lansing, MI
    Title says it all - discuss :D
  2. backporchmusic
    backporchmusic Friend of Leo's
    Why, yes. Yes you do. And you can take that to the bank.
  3. Mayas caster
    Mayas caster Tele-Holic
    Caraquet N.-B. Canada
    Why not????
    corliss1 likes this.
  4. Guitarteach
    No.. You need a JMP!
  5. LuthRavin
    LuthRavin Tele-Meister Ad Free Member
    Eugene, Oregon
    Oh for sure you do!! No explanation needed..just do it
  6. Shuster
    Shuster Poster Extraordinaire
    Bulverde Tx.
    How have you made it this far without them?
  7. schmee
    Maybe.
    The PR is great for recording and very small gigs.
    The DR, if set up properly, will do 90% of gigs other than outdoors or large venues.
    The VR (or any similar 2 x 6L6 Fender BF type) will do those larger gigs, outdoors etc.
    If I had to eliminate one it would probably be the PR as the DR can fill that slot, but less easily.
    trouserpress likes this.
  8. corliss1
    Lansing, MI
    @schmee - that's kinda where I was going with this. I have all three, they all sound killer, but I'm pretty sure the DR can do everything the PR could. Being a tech it's not like I'm amp poor or anything.
    schmee likes this.
  9. Dacious
    Dacious Poster Extraordinaire
    Godzone
    Apart from the beautiful trem (and TBH I hardly used mine) I think the PR is least useful. It does have that touch-feel thing of the cathodyne inverter going on which I don't think my VR had.
    The Superchamp with a better speaker and a cap clipped bridges the gap between PR and DR. Adds adjustable gain and a useful mid boost and overdrive to the mix. DR output transformer so it's not as farty as the PR.
  10. corliss1
    Lansing, MI
    The trem is more...............natural I think? But doesn't have the depth of the others either, even after some bias tweaking. It would record killer though.
  11. nojazzhere
    Foat Wuth, Texas
    I had to get out a dictionary and look up the word "need" as it relates to gear acquisition. It simply said "SEE ENTRY FOR WANT".
  12. corliss1
    Lansing, MI
    nojazzhere likes this.
  13. telemnemonics
    Sell them all and buy one of the boutique Princeton size amps that take both 6L6 and 6v6, plus has some mid forward capability on one extra knob, neg feedback on another extra knob, and maybe a boost thrown in for Brutish measure.
    To keep some of the PR portability you might want to limit total power to 35w, but that was on your list already.
    Lose the rectifier tube and replace it with a fixed/ cathode bias switch for you squishy PR/ punchy (er) VR sounds and you'll be happy for weeks.
    Then you'll shop for more amps...
    IMadeYouReadThis and jimash like this.
  14. teletimetx
    teletimetx Doctor of Teleocity
    Houston, TX
    ...Italicized and bold face: says it all right there. Of course, you neeeeed all three. The little PR is (IMHO) good for a bench test amp, in fact all three could serve, if only to demonstrate to your customers what their amps should sound like. Right? Yep.
    Ok, plus, I have a tetchy back, that sometimes requires that I have to tough it out and take the smaller amp to a gig, rather than the heavier iron. Now, maybe that's not a problem you have at this exact moment, but a person needs to plan ahead...
  15. uriah1
    Around
    Probably omit the VR
  16. corliss1
    Lansing, MI
    WAT - if anything, I'm thinking PR.
    telemnemonics likes this.
  17. fendrguitplayr
    fendrguitplayr Doctor of Teleocity
    Greater Boston
    No, you need a Pro Jr, DR, SR and maybe a TR.
    W.L.Weller and vgallagher like this.
  18. corliss1
    Lansing, MI
    @fendrguitplayr - I have a TR I pulled out of a swamp. It had been sitting there for 15+ years. Luckily it was on casters so no damage to the cab. Did a basic cap job and it fired right up. Isn't pretty though :D
  19. telemnemonics
    Yeah, while the small amp craze subsides a little, I find I long for the punch and clarity of a bigger amp more than I long for a smaller amp with little headroom.
    Even my preferred 18w Marshalls are often not really quite enough, and they have bigger bottom and more punch than a PR.
    If you need the PR for controlled volume gigs where you just can't be satisfied unless your small amp is cranked to some cosmic sweet spot; you won't be asking this question.
    Same with the weight; if you can't lift a DR you're not asking if you should get rid of the PR.
    I tried vintage PR 20 years ago before the small amp craze really hit hard, and just couldn't find what a few players then loved about the mushy bottom little bugger.
    Noting that some years earlier they were so unpopular that Mesa was gutting them to use just the chassis and cab for MKI Boogies.
    Now that college dorm amps are all the rage, time to sell!
  20. Lawdawg
    Lawdawg Tele-Afflicted
    Atlanta
    I'm probably in the minority here, but I think a DR covers 90% of the ground of all three. Certainly cool if you can have all 3 though!
    Tim S, Chiogtr4x, 41144 and 2 others like this.
