do i need special pickups with a delta tone harness?
  • Thread starter kristen
kristen
florida
can a delta tone harness be used on a "regular" mexican stratocaster or do I have to get special "delta" pickups?
thanks
super kristen
kristen
florida
i have a prewired "delta-tone" harness (pots and switch). i would like to put it in a mexican stratocaster which has the regular pickups which came with it. i think this harness needsto connect to special pickups but i am not sure.
k
jefrs
Newbury, England
Methinks the 'delta tone' is the no-load tone pot ? = ordinary pickupses.
Just copy the wiring over from the old one (take a photo for reference).
mellecaster
Former Member
Desperadoville..USA
The Delta Tone Rig did feature a Hotter Bridge Pickup...but there's no reason you can't just wire it up to what you have, measure twice...cut once...;)
kristen
florida
thanks guys. yes, i believe there was a reference to a "no load" in the description about the harness when i bought it. is that supossed to be for a better sound.. or just a different sound?
kristen
Deaf Eddie
Beautiful Idyllwild, CA
I confirm: The complete "Delta-Tone" system was comprised of three things:
#1 - one no-load tone pot in the lower control location;
#2 - 5-way wired so that the no-load tone pot affected the mid AND bridge pickups;
#3 - a slightly hotter bridge pickup.
These axes also all have the RW/RP middle pickup, but that's not a Delta-Tone exclusive idea.
The idea with the no-load running the mid and bridge pups was threefold:
#1 - the #2 throw, neck+mid, would now only have ONE tone pot constantly attentuating the highs, for a slightly brighter quack;
#2 - with the no-load, the mid pup would be slightly brighter/punchier, without the constant roll-off of a tone pot;
#3 - the bridge pup retained its "no-tone-pot" brightness, but could now be "tamed" with the no-load tone pot wired to control it (and the mid pup) at the 5-way.
The hotter bridge pup was an attempt to get a better balance between the three pickups, compensating for less kinetic energy (ergo, output) produced near the bridge.
You can use any of the "Delta-Tone" ideas on any Strat (or other 3-pup guitar with a 5-way).
Radspin
Long Island, NY
I use a Seymour Duncan Little '59 bridge humbucker with my Delta Tone Strat and it works fine--in fact, the tone pot is extremely useful in getting different tonal "flavors" out of the Little '59.
