. I have a 2019 Fender ‘57 Custom Deluxe that I love cranking up to its gloriously saturated sweet spot, but that’s not always practical, so I looked into attenuating it and here are a couple reviews I did regarding two different type of products I got to specifically use with my Deluxe:
Like a lot of players I have a few amps that are way too loud to enjoy playing in certain situations, so I decided to go the "attenuation" route. After reviewing several options (both low priced and high end) I figured I'd try the low priced version first; For a couple reasons: 1) The higher...
www.tdpri.com
` I'd like to start this review off by pointing out how the Fryette PS-100 is often referred to as an "attenuator", but that label grossly minimizes what this device really does in my opinion. Sure, it can attenuate - in the sense that you can turn it down - but functionally it's still a vacuum...
www.tdpri.com
In my case the more typical Bugera attenuator failed to deliver (when used with the 5E3 Deluxe) while, as far as I can tell, the Fryette PS-100 would work equally well with just about anything, but is of course far more expensive.
So, bottom line, the cheaper ones may not do the trick, while the more expensive one may be overkill.
As more me?
If you read the above reviews you would have probably gathered that I managed to find a way to use each of them, but the Fryette PS-100 is the best of the best as far as I’m concerned.
Anyway, Good Luck!
