mabinogeon
Hi all,
I found a schematic for Weber's Tru-Load dummy box, and I'd like to knock one together for myself since it appears they don't sell them anymore:
Two (or more) questions:
1) I’d like to double-up some 100W wirewound resistors for the sake of heat dissipation. Instead of two 16Ω 100W resistor in parallel to get 8Ω 200W, say, could you just as well use two 4Ω 100W resistors in series to get that same 8Ω 200w rating? I know the math is there, but is there any reason parallel is preferable to series in a situation like this?
I don't have any speaker motors laying around the shop, but I do have a working 8Ω 100W neodymium speaker that I could mount in there.
I'm having a hard time visualizing this for some reason, and way over thinking it! Wouldn't an 8Ω speaker in parallel with an 8Ω resistor present a 4Ω load to the amp? Would you need two sets of resistors in there, one for when the speaker is in the circuit and one for when it's out? That doesn't seem right. Does using just the speaker motor somehow react differently than using a complete speaker? Clearly, I don't know a ton about speakers.
Alternately, I have an old 8Ω 50W Becker speaker that I could use for parts, but then how does one hook up just the motor portion of the speaker without having the leads attached?
Bonus question: Mouser has both inductive and non-inductive wirewound resistors. If one uses inductive resistors, could the speaker motor in this scenario be eliminated all together? The non-inductive are twice the price of the inductive resistors. I'm assuming that's one of those things that matters in the hifi world, but not in the guitar amp world. I also see these low-inductance dummy load resistors which claim to made for just our purpose.
I think I've made it abundantly clear that I have no idea what I'm talking about in this scenario. Apologies.
