DIY Power Supply: check me?
Discussion in 'Burnt Fingers DIY Effects' started by Mark the Moose, Oct 27, 2020.
  1. Mark the Moose
    Mark the Moose Tele-Holic
    Erie, CO
    I'm thinking I'll take a shot at my own power supply. I found this schematic in an instructable awhile back and saved it. Today I put together a stripboard layout. Figure I'll use a cheap wall-wart transformer or laptop power supply...something in the 12 volt/4-5 amp range. That should give me plenty of juice. Thoughts?
  2. Switchy
    Switchy Tele-Afflicted
    Arizona
    I'm not an electronics engineer, but I'll offer my opinion.
    1) It's not supplying isolated power to your pedals, so it's basically no better than a wall wart daisy chained.
    2) The 780X series are somewhat noisey and require good filtering, and if I was doing a circuit, I'd be using a combination of capacitors for each. Ex: 100nF and 100uF in parallel
    Just my thoughts
  3. LightningPhil
    LightningPhil Tele-Meister
    Nottingham, UK
    Little isolated power converter modules are reasonably inexpensive. There would be a little noise, but filtering should be trivial. The alternative isolated PSU method is separate transformers (or separate windings from a single one) with individual regulators.
    Something like this, though a little spec sheet reading is advised:
    https://uk.rs-online.com/web/p/isolated-dc-dc-converters/1874589/
    Mark the Moose likes this.
