DIY Neck Finish
Discussion in 'Tele Home Depot' started by HBamps, Nov 11, 2009.
  1. HBamps
    HBamps Tele-Meister
    Alameda, CA
    I am considering buying a unfinished Allparts TMO-Fat neck for my latest build with plans to finish it my self. I have zero experience here but thought the vast knowledge on this forum could help.
    Is there a relatively easy way to finish a neck? Like possibly a rub on solution? I did a search but did not come up with anything. I am wondering what it intails.
    Any links or information would be much appriciated.
    Thanks!
  2. jrich99
    jrich99 Tele-Afflicted
    AZ
    I just finished my first ever neck finish with Guitar ReRanch Supplies:
    http://reranchstore.stores.yahoo.net/fencuscol.html
    I used the Fender Neck Amber and the Nitrocellulose clear coat. I was refinishing a Squier neck, and the hardest part was sanding down the old neck-The actual finishing process was a piece of cake. I just did it in my back yard. If you do choose to go this route, PM me and I'll give you all the details/help I can...
  3. hackworth1
    hackworth1 Friend of Leo's Vendor Member
    Volusia County, Florida
    You could use tru oil. You could use shellac. I'm going to try the real shellac flakes and denatured alcohol for a quasi-french polish.
  4. j.b.horns
    j.b.horns Tele-Meister
    Utah
    Browse through the finely finished sub-forum. You should find at least a couple tru-oil threads on the first page. There's one about shellac too.
  5. Joefaity
    Joefaity Tele-Meister
    Washington (the good one)
    Tru-oil!
  6. Curly
    Curly Tele-Meister
    San Diego, California
    Tru Oil indeed ... done well, it feels better than nitro, IMO.
  7. fernando
    fernando Tele-Afflicted
    Barcelona, Spain
    for rub on you can use shellac with some tint.
    Easy, natural, non toxic and beautiful look and feel.
  8. jrich99
    AZ
    I like the nitro because it is more "Fender Accurate", and the tru oil supposedly is more likely to warp.
  9. mwaym
    mwaym Tele-Meister
    anderson, indiana
    Please explain jrich99. This is the first I've heard about a tru-oil neck warping !!!!! I've always heard Tru-oil was great. I'm about to do a neck, so I need to know the facts. ;)
  10. mellecaster
    mellecaster Former Member
    Desperadoville..USA
    I've done about 30 necks in Tru Oil...the warping must be another one of those Internet myths ?
  11. tonyw
    tonyw Tele-Meister
    Melbourne Australia
    I have ajust done a tru oil neck what could be easier.
  12. Hollmanp90
    Hollmanp90 Tele-Afflicted
    Hamilton County
    I've used also.........No problems.
    Why would Tru-Oil be more likely to warp ?
    To believe that and post that repsonse......Give your reasoning,please.
  13. Colt W. Knight
    Garland, Maine
    You do realize Truoil was developed to finish firearm stocks right? I can say with the utmost confidence, that if truoil was prone to warping wood, it would not still be on the market. Who wants a crooked rifle or shotgun?
    Truoil is a hard finish, not an oil-type finish. "True" oil-type finishes or wax type finishes will allow more moisture to diffuse through to the wood than hard finishes, but as stated before, truoil is a hard finish and easy to apply as well.
  14. maumari
    maumari Tele-Meister
    Rome, Italy
    Tru-oil, simple to apply and effective to use!
  15. walpow
    walpow Tele-Meister
    Los Angeles CA
    Another vote for Tru-Oil. I've always avoided finishing anything (not just guitars) because I invariably got crap falling from the air into the finish and it looked and felt lousy. But I recently got two instruments (Ibanez Mikro bass and First Act Sheena) that, if they had any finish on the neck, it was negligible. Did them both in Tru-Oil - about eight coats each. The Mikro was perfect. The Sheena had a couple of rough spots, and steel wool took care of that without messing up the finish. It's simple and pretty quick - I did two or three coats a day, then left them for two weeks before handling. I'll be using Tru-Oil on the neck of the Tele bass I'm building, and maybe the body too. (Assuming I ever acquire the body.)
  16. Citizen_Insane
    Citizen_Insane Tele-Meister
    Iowa
    Tru-Oil. It's more than just an oil finish, it actually hardens. Warmoth considers it an acceptable finish to keep the warranty, so I wouldn't worry about it. If they thought it would warp necks, they wouldn't replace necks that were finished with it.
  17. 68thinline
    68thinline Tele-Afflicted
    Hoggetowne, FL
  18. lsdtele
    lsdtele Tele-Meister
    Carthage, TN
    How do you go about finishing with Truoil?
  19. j.b.horns
    Utah
  20. thepassivevoice
    thepassivevoice Tele-Meister
    los angeles
    I think this association with oil finishes is the basis for the view that Truoil will warp necks. Others on this forum have also questioned Truoil's long-term durability (compared to nitro lacquer). I suppose if the finish didn't last long, the neck would then be susceptible to moisture. But as Citizen_Insane points out, Warmoth considers it a satisfactory finish.
    I wouldn't hesitate to use it on a neck. The method recommended by LMII will produce good results without all of the nitro-lacquer hassle.
