DIY Home studio Furniture
nedorama
I'm no Norm Abram, but in my home studio, the corner with my Tremolux was always kind of a mess; the wooden box to the right of the amp is actually a bookcase with my younger daughter's piano music, which she can't really get to. Now, she's got access to her music, my amp is right there, and I now have a top shelf for more gear. Or a plant which my wife is suggesting...
This was my first time using Kreg pocket screws; wood is 3/4" plywood and 1x2 finishing strips. It's basically 2 boxes screwed on top of each other. Lots of sanding, staining, satin polyurethane, more sanding, etc. Happy with how it came out.
If I were doing it again (and will be on the right side):
  • water-based stain and poly - cleanup is a LOT easier.
  • I don't have a lot of room, but if there was a way to sand and stain before assembly I think it would look better.
  • While this is 18" deep, I could stick with 12" hardwood boards and go for a better grade wood.
  • I need a nice hunk of masonite or plywood as a stable base to cut on; was using an old cabinet door (2x4') and wasn't the best.
  • Would have pocket screwed the face frame together, and then pocket screwed it to the carcass.
  • Would have made it slightly narrower, as 4' is pretty wide and there's a lot of negative space on either side of the amp.
For the right side, it's about elevating a Dr. Z MAZ 18 Jr and a Princeton Reverb, but also adding 8-10 units of rack space underneath the Princeton.
At least now I have the tools for it - thankful my old Dewalt cordless drill battery died as I ended up getting a Ryobi drill, nailer, circular saw and the Kreg cross-cut jig. May get their orbital sander next for the next one...
swarfrat
US
Nice. I like the look of the Argosy desks but the price isn't happening. And I'm not even sure if they're as functional as they look. (For one thing I don't think having a midi keyboard front and center is ideal). And while they might be awesome with a console in the center, I'm not sure it's similarly ideal for a PC/monitor/control surface setup.
24 track
kamloops bc
it all depends on function over form , argosy designs have a ton of detail worked out for you in advance , as for the midi keyboard on the console is a good Idea for when you are addressing the daw and through midi can control many functions of the studio .
this is my design and its perfect for me I built this for about 300.00 complete and the function is totally expandible.
I use Logic as a daw because through the Daw environment I can control and script all midi functions of all my midi gear, truely a remarkable thing.
there are 5 mac towers in operation here and one power mac I use for device editors
this guitar rack is also under midi control to the daw
as well as the synth system
so it all gets back to function
swarfrat
US
Egads... I don't have a ton of synth stuff... JV880, Multipad. Keys aren't my strength either (Actually have a Yamaha G50 in the rack I hope to get integrated someday). Does the keyboard at the desk slide away, or is this used for nothing but music? I have a QX25 and a Q49 - I'd sort of envisioned stashing the Q49 over at the drum kit (I have a pedal and snare pad at the multipad, and can swap out the pad for a real snare in a few seconds) - just to have transport controls and a few keys over there.
24 track
kamloops bc
everything folds up out of the way nice and neat , even the synth rack the shelves are retractable
I use a kurzweil K2000at the console and Korg M50 with the synths
how do you like the JV880? I have one as well also a D110 plus a few other sound modules that I plan to incorporate into the rack I like the brain for the alesis DM5 as it gives me separate trigger ins for 16 pads that i can use with the sequencer trigger outs ( i've also have 8 pads if I want to go there )
swarfrat
US
I need learn it better. I got it looking for a hardware module to cover basic sounds (and I figured 90's was good enough since they quit making good music about then). A rompler or VST might have been better but they're sort of a pain (but doable) in Linux. I literally need like about 4 B3 sounds, about two Rhodes, an acoustic piano, but lots of killer horns. The horns have been disappointing so far, but it might just be the time invested so far.
Not counting a power strip and crossover (which could change if I ever add a JBL LSR10 sub) i basically have three spaces of audio and three of midi. (Patch bay, RX1602 line mixer, Behringer UMC1820 interface on the audio side. Yamaha g50, AMT8 midi patch bay/interface, and the JV880. ) An X-touch, and my computer monitors are stacked vertically.
I'll have to think about where the X-touch and keys should go. I'm trying to avoid a super deep desk (currently it's 3ft deep and kinda crazy)
New Posts
