Lowerleftcoast
Your measurements on the 6V6GTI had these parts from years ago and decided to try to put together a 5F2A.
PIN 3: 434 VDC
PIN 4: 372 VDC
PIN 8: 23.8 VDC
Plate to cathode voltage ~ 434 - 23.8 = 410.2
You have a 500R 6V6 cathode resistor. (We don't know the measured value.)
Using Rob Robinette's bias calculator for a 14W 6V6, the plate dissipation is approximately 132.1% of MPD.
(I like using Rob's calc because it is easy and it subtracts an approximate 5.5% for screen current.)
132.1 %MPD is very high. The tube may be able to take it. Maybe not. Sometimes tubes will do odd things when pushed past limits. I wonder if the harmonic sounds might be because of this.
I am curious about the filter capacitors. You say the parts came from parts you have had on hand from years ago. Capacitors have a shelf life. The harmonic sound is consistent with bad filter caps or poor connection to the caps. My spidey-sense has a concern with the two black/gray reservoir capacitors.
6V6 can run with ~420VDC plate to cathode. 6V6 endure this on many amplifiers by design, (Princeton Reverb). So, imo, it is safe to keep the PT. The high voltage will make the 5F2A sound/act different than the low voltage tweed line it came from, but it will work and you may like it. We can't tell you if it is worth changing to a lower voltage PT.
My plan of attack would be to reduce the 6V6 current. A vintage rectifier tube might reduce the B+ enough to accomplish this. Changing the resistance of the 500R 6V6 cathode cap will accomplish this. This will increase the B+ a little but I doubt the 6V6 plate to cathode voltage will exceed 420. (Hopefully you have resistors on hand to change the resistance to around 600R.) You could also try a different 6V6. Chances are a JJ 6V6 would have a happy life in this amp.
If the harmonizing effect continues, focus in on the filter caps.
Once the amp is working correctly, you can decide if the high voltage 5F2A version is to your liking. If it is, then address the high heater voltages with resistors/diodes etc.
No one has mentioned a *bucking transformer* yet. This will reduce all of the voltages in the amp. It could solve all the high voltage issues at once.
