heybluez74
I am working today so won't be able to get to this till later but I am planning on triple checking all my connections/wiring just to make sure I did not make a dumb mistake... more soon
So best to get a proper PT?The transformer is rated for 600V @ 173mA, almost double the current usually used. Due to this there is less sag across the secondary winding causing the high voltage. Putting a 600R resistor in place of the 500R will cause less current but will also increase the voltage a little. So not the way to go. The heater voltage is 3.6 x 2 = 7.2V rather than the 6.3V. The winding is rated for 5A, you are drawing 1A.
Will you be using the current transformer for another amp? If not and you do not want to spend the money you can reduce the voltage by putting resistors in series with the heaters, zener diodes for the supply voltage.So best to get a proper PT?
Curious -- when I look at the spec on the box of my Hammond 272FX it looks like it is rated for 600V 150m ADC, not 173mA. Where are you getting that from? (asking so I can learn)The transformer is rated for 600V @ 173mA, almost double the current usually used. Due to this there is less sag across the secondary winding causing the high voltage. Putting a 600R resistor in place of the 500R will cause less current but will also increase the voltage a little. So not the way to go. The heater voltage is 3.6 x 2 = 7.2V rather than the 6.3V. The winding is rated for 5A, you are drawing 1A.
Also, would I use the GRN/GRN-YEL to get 6.3V to the heater? Right now, using GRN-GRN.
I must have gotten the budget version...lol. It only has 2 blk wires.
PIN 4+6
Measured AC probe on ground and pin 4 or 6: 342V
PIN 3: 434 VDC
PIN 4+6
It 'works' but the output is distorted and weak.
PTI recommend starting with the VAC the power transformer is putting out and go from there.
Can you take a picture of your input jack?
reversing the OT wires fixed the distortion and weakness. Now it is a hum/buzz.... also strange is that I can wave my hand over the preamp section (12AX7) and it will have an effect on the noise. Grounding issue?your voltages, current and plate dissipation are all in range, although on the high side, especially for a tweed circuit.
being a little high will not cause
unless the tube is no good.
With the tube dissipating 19W how do you suggest cooling it down?As fender amps go, 300-0-300 is low. (tweedish?)
the plate voltage is not too bad. The plate dissipation Is high and only too high for a tweed amp but not for a BF/SF champ which this amp is not.
he has
434 plate minus 24 cathode for 410 volts. High for tweed but not too high for a BF/SF champ.
PT
RED — 688VAC
YELLOW - 5.65 VAC
It might drop more voltage with a vintage 5Y3.
