joulupukki
While contemplating an upcoming possible RR763V 6V6 Blackvibe build, I came across a decent deal on a used (2013) Deluxe Reverb Reissue in my local classifieds and couldn’t pass it up. I actually did the same thing when I built my Mojotone Princeton Reverb (bought a PRRI as a reference and sold it after I had finished my build).
It plays wonderfully and part of my reasoning for picking it up was to know whether I wanted to proceed with the hand-wired Blackvibe build. But, the tremolo doesn’t sound nearly as incredible as the tremolo on my Mojotone PR. So, I popped it open this morning with the intent to change the two tremolo capacitors to at least have the option to slow down the tremolo a bit more.
That’s when I discovered a few modifications have been done on this amp (very cleanly, thankfully).
From what I can see so far, the mods so far are:
- Plate and cathode wires from the board to the tube sockets of V1, V2, and V3 are twisted together (I assume to help in removing hum)
- Bright cap on Vibrato channel is removed
- A small capacitor has been added in parallel to R28 (the first resistor going to ground after the signal comes back from the reverb tank)
- A capacitor has been added across the opto-isolator (I assume to fend off possible tremolo ticking)
- The resistor R27and capacitor C15 has been moved from the board to V3’s cathode and soldered directly to the chassis
- Capacitor across V3’s plate and cathode added
The amp is otherwise in great shape. The main filter caps still look good (the seller said he’s probably only put about 30 hours of playing on it in all these years – he was the first owner). It’s got two RCA 6V6 GTY power tubes in. I’ll be double-checking the bias after changing the tremolo caps.
I am obviously ignorant, but didn’t realize it used an opto-isolator in the tremolo circuit and don’t really understand that part of it yet. But, I do know that when I turn the speed control all the way down, it’s still not that slow. Also, when I turn the speed up, the tremolo effect kind of disappears for a few seconds when I reach the upper end of the pot and then it comes back, but super insanely fast and almost not even noticeable.
The intensity pot on the trem is also … way too much for my liking and generally just not very smooth. Hopefully switching the first two 10nF caps to 20nF will at least slow it down. I’m sure there’s more I need to learn about how this all works.
The other mod I will probably do while I’ve got it open is the robrob normal channel reverb mod.
Here are a few gut shots…
